 Advice? Adding 2nd battery and charger
windsong
Initially Posted - 10/06/2009 :  06:02:46  Show Profile
I'd love to hear anyone's advice before I begin this project. I'm adding a second battery, isolator switch and Xantrex 10TB charger to Windsong. I plan to move the existing battery forward to the starboard locker and put the new battery in the port locker, getting some weight out of the stern. I'd LOVE a schematic, if anyone has one. I haven't decided where to mount the shore power input. Overall, anything to watch out for? Thanks in advance.
Michael Hetzer
"Windsong"
2009 Catalina 250 WK HN984
Myrtle Beach, SC
Response Posted - 10/06/2009 :  16:51:22  Show Profile
I have both of my batteries in the aft area. Here is how I mounted the electronics (the little round device is a digital 12V meter):
Here is the 120V outlet:
Here is the shore power connection round object forward of the outboard):
I connected the two batteries together so no isolator switch. I'm not convinced a simple 12V system on our boats needs the batteries to be isolated.
Stu Jackson C34
Response Posted - 10/07/2009 :  23:56:07  Show Profile
I agree with Nautiduck, two batteries in one larger bank is fine for a C25. No isolation is needed. Just think of it as a much larger (double) size than one battery. If you have a manual pull on your outboard, you don't need to separate your two batteries, make it into one big bank.
Response Posted - 10/08/2009 :  03:25:03  Show Profile  Visit OLarryR's Homepage
My batteries are hooked in parallel with no isolator either. I have a 20 watt solar panel that keeps them charged and a digital controller for the panel to monitor the volts/amps, prevent overcharging and drain back thru the panel. I keep my battery switch on 1&2 all the time. I just make sure I turn off all switches on my 2 switch panels (original and the new one I installed).
Edited by - OLarryR on 10/08/2009 03:26:04
Response Posted - 10/08/2009 :  09:14:49  Show Profile  Visit delliottg's Homepage
We've got two batteries that I just installed about two weeks ago. I mounted them on top of the original battery box using some aluminum "L" brackets an WM battery hold downs. You can read about it [url="http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=20505&SearchTerms=SL,has,two,new,batteries"]here[/url]. The narrative's a bit spotty, but photos might help, very similar to Randy's install. I was pretty frustrated when I wrote it, so not my best work. There are better pictures towards the bottom.
I chose not to use a switch & simply hooked them up in parallel. We've got an 18 watt solar panel attached to a Sunsei controller that keeps them topped off. It turns out that I may not have had to replace my old battery. I discovered that I was only getting about 5 volts at the other side of my solar controller, but the solar panel was putting out about 18 volts. A couple of minutes with a corrosion buster pen and I was getting 13-14 volts at the regulator, which may have been my problem the whole time. Oh well, at least now I've got two brand new batteries that I know their entire history, where before I knew next to nothing about the original battery.
I know this wasn't exactly the information you were looking for, but maybe it was helpful.
Turk
Response Posted - 10/12/2009 :  05:01:30  Show Profile  Visit Turk's Homepage
I added 2 batteries to the bow for the extra weight up front.
Here is the link
http://www.elmhurstprop.com/webbat/Photos.html
