 Engine Lock help needed!!
Ben
Initially Posted - 10/19/2009 :  07:00:48  Show Profile
Hi All,
Sad day yesterday, took Adventurous out of the water for the year. Adding to this sad day, the key to the Master Lock in my engine lock won't turn, thereby preventing me from removing the lock and taking the engine from the boat. This is the style of engine lock I have:
As you can see, there is no room to get bolt cutters on the lock itself. Anyone know if a good way to remove this lock inexpensively? I DO plan on working on the lock some more with the key to see if I can get it to work, but I'd like to have a plan in place in case the lock remains stubborn.
Thanks all!
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
Ed Cassidy
Response Posted - 10/19/2009 :  07:40:25  Show Profile
Find a thief, they can show you how to do it in less than 60 seconds! Sorry. I would think that plenty of WD40 should work, just don't force the key. spray down around the top of the lock and let it soak a few minutes. Push down on the lock while pushing up on the base to loosen it up, then try to turn the key. Don't use any more force than you would normally use on a key. Wiggle the key back and forth and above all, make sure it is the correct key for the lock. I know, you probably already tried all of this and you may get to actually test out how secure the lock actually is. Keep us informed.
Ed
Response Posted - 10/19/2009 :  08:14:56  Show Profile
My first thought was that maybe you've got the wrong key. Don't ask why this thought occurred to me
WD-40 might work but I think graphite lock lubricant might be better. How old is the lock? Since you're in fresh water, I would think that corrosion shouldn't be a huge problem.
Response Posted - 10/19/2009 :  10:14:16  Show Profile
Depending on the size of your outboard's handles, you could probably pry open the lock's slot enough to pull the lock off the handles.
Response Posted - 10/19/2009 :  10:40:16  Show Profile
I had the same problem a few years ago...I just cut through the tab at the opposite end of the slotted side, and slide the bracket off w/ the lock in place.
Response Posted - 10/19/2009 :  10:40:30  Show Profile
I'm in Kansas, so I can't check what the brand name is on Lysistrata, but there is a very good penetrating oil that works better than WD40 in a bright yellow can... Something Blaster? It works. Other than that, your only real option is a torch. Those locks are designed that way for a reason.
sten
Response Posted - 10/19/2009 :  10:57:30  Show Profile
After applying some WD-40 or "Something Blaster", a whack with a hammer (with the key out) might jar something free.
Response Posted - 10/19/2009 :  11:01:18  Show Profile
Cut it off with a masonry blade.
Response Posted - 10/19/2009 :  11:11:03  Show Profile
Angle grinder with a cut-off wheel. Take about 60 seconds.
Ben
Response Posted - 10/19/2009 :  13:32:07  Show Profile
Thanks all,
If indeed I cannot get the key to work after appropriate remedies are attempted, I will cut the area opposite the lock as suggested by Jerlim.
Thanks so much for the ideas.:-)
Response Posted - 10/19/2009 :  16:49:08  Show Profile  Visit delliottg's Homepage
I think you're talking about PB Blaster, which I've used with good success, but keep in mind this caveat: http://www.sailnet.com/forums/gear-maintenance/33279-pb-blaster-penetrating-oil-warning.html
Rich P
Response Posted - 10/19/2009 :  21:10:09  Show Profile
Kroil sold by Kano Labs is by far the best spray I've ever used.
As for getting the lock off, a dremmel and a cut off wheel would go through the lock pretty quickly and if done carefully, you should be able to reuse the bar.
Response Posted - 10/20/2009 :  06:40:23  Show Profile  Visit britinusa's Homepage
Sooooo! How many of us are rushing out to our boat and checking the lock still works?
Response Posted - 10/20/2009 :  07:30:30  Show Profile
<br />I think you're talking about PB Blaster, which I've used with good success, but keep in mind this caveat: http://www.sailnet.com/forums/gear-maintenance/33279-pb-blaster-penetrating-oil-warning.html
Yes, that's the stuff... It is powerful and yes there are warnings all over the place on the can. Some PB Blaster and perhaps some heat applied should do the trick...
sten
Response Posted - 10/20/2009 :  07:58:01  Show Profile
So if some PB drips into the water and forms a slick, does it cut a slit through your transom at the waterline?
PZell
Response Posted - 10/26/2009 :  21:04:20  Show Profile
Just ran across this query. I have had several of these types of motor locks and finally gave up on them. They eventually seize up. If you catch it soon enough, you might get the lock free with penetrating oils as mentioned above. I can now get this device off the motor in a few seconds. All you need is a bar to pry the slot wide enought to get it off the motor screw on knobs. So, it's not very effective anyway.
Response Posted - 10/27/2009 :  05:20:50  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PZell</i>
<br />I can now get this device off the motor in a few seconds. All you need is a bar to pry the slot wide enought to get it off the motor screw on knobs. So, it's not very effective anyway.
Yep.
Gloss
Response Posted - 11/04/2009 :  15:56:29  Show Profile
and now they have battery powered 4" side grinders. Just put in a cut off wheel and now you are in business for some really easy thievery. Just what we need.
Thanks for the heads up on PB blaster
cat25
Response Posted - 11/16/2009 :  02:35:36  Show Profile
Try using a hack saw with a screwdriver under top of lock to hold it up while cutting.
Response Posted - 11/16/2009 :  20:45:00  Show Profile
No locks prevent theft, they just divert thieves to easier targets. The ever-faithful Dremel works wonders
EAbrams
Response Posted - 11/23/2009 :  06:50:01  Show Profile
Just found this article on a couple types of [url="http://www.sailorssolutions.com/BodyPages/Other/BoatWorksLocksReviewFall2006.pdf"]Motor Locks Review[/url] . May be of interest to a few.
Just looked a little deeper and found that the Editors Choice (Stazo Smartlock) apparently doesn't fit the following motors.
Known engines that the Smartlock does NOT fit:
Evenrude 10 and 15 HP 2-stroke
Johnson 15 HP 2-stroke
Mercury 4 HP 4-stroke long shaft
Mercury 9.9 HP 2-stroke
Mercury 15 HP 2-stroke
Mariner 15 HP 2-stroke
Nissan 8HP 4-stroke 2006
Nissan 9.8 2007
Nissan 9.9 HP 4-stroke 2006-2007
Daihatsu 6HP 4-stroke model MSS66BL
Honda 20HP 2006
Honda 15HP 2007 model BF15DKSH
Tohatsu 9.8 hp four stroke
Yamaha 15
Edited by - EAbrams on 11/23/2009 07:04:16
Dave Otey
Response Posted - 11/24/2009 :  09:59:29  Show Profile  Visit Dave Otey's Homepage
Ben, is it possible the mechanism was installed with the keyhole in the up position? I install mine with keyhole down. Works great, going on fifth year.
