 Draft question. C-250
pwhallon
Initially Posted - 10/28/2002 :  09:43:19  Show Profile
Hi Gang,
Although sailboatless, I recently purchased a trailer for a 1998 Catalina 250 wing keel.
I am looking for a C-25 as soon as I sell my powerboat.
Here is the question.
What is the draft of a Catalina 250 wing keel? The online brochure only shows the swing keel model.
I am curious because I may end up with a wing keel or a fin keel boat and need to know what the potential adjustment to the bunks may be.
ssteakley
Response Posted - 10/28/2002 :  11:21:40  Show Profile
Paul,
the 250WK draft is 3'6", here is the link to the specification page: http://www.catalinayachts.com/c250_wk.phtml
I also just bought a used trail-rite trailor for my 250WK. I keep my boat in a slip and will only use the trailor to take the boat out for maintance. Can you (or anyone else) tell me how you prepare the height of the pads? Should the boat rest on the Keel and the pads are just for balence? Or do the pads hold the weight of the boat?
I used this trailor for a recent bottom job but I was on the boat and did not get to see how my experienced help adjusted the pad height. We did use a 4x6' block of wood between the trailor and the keel. I am concerned about this due to reading post where some report a seperation of the keel from the hull when a boat is trailored a lot and the weight is on the keel. Any other importnat tips on loading a boat onto a trailor will be helpful as well,
Steve Steakley
Moon Chaser #385WK
pwhallon
Response Posted - 10/28/2002 :  14:24:05  Show Profile
Hi Steve,
Thanks for the help.
My experience has been that with a fixed keel boat, wing or fin, the keel takes the weight of the boat and the bunks are adjusted up to the hull to stabilize it. I had a 1986 swing keel C-25. The boat sat on the rollers and the keel was lowered to rest on the trailer.
This is why it's so important to let the keel determine the "attitude" of the boat.
Old style 25 wing and fin keel boats will lean forward because of the angle of the bottom of the keel. If you put weight on the back of the keel you can get some seperation of the keel, and keel stub, at the front of the keel.
I watched a Catalina 27 being loaded on a trailer. The crew set the keel down on the trailer with a travel-lift. They let it rock forward until it was stable. Then they adjusted the screw pads up to the hull.
Here is a picture of my previous boat. A 1989 Catalina 25/wing "ESSAYONS" on her trailer. See how she leans alittle forward.
<img src="http://im1.shutterfly.com/procserv/47b2ce09b3127cce912fcee641500000001410" border=0>
Thanks again for the help Steve,
kirkh
Response Posted - 10/30/2002 :  22:18:07  Show Profile
I just had my newly purchased C-250 hauled out to move to a different lake. The guy used one of the "one size fits none" universal trailers. An unusual thing happened when we pulled it out at a ramp: even though the aft end of the wing keel was at least 12 inches in front of the forward axle (with the weight on the keel), it was still "back end" heavy with negative tongue weight. The only thing that was left in the aft section with any weight was the battery.
We had to fill the water tank, move all the heavy items as far forward as we could, and then add 280 pounds of cement bags to the v-berth. After all of this, it pulled great!
The more experienced sailors at the lake had never seen anything like it and everyone agreed that it defied the law of physics. I think a trailer especially designed for the C250-WK would have made this job much easier but I couldn't find one.
Kirk
C250WK #490 (oh, and 280 pounds of cement) :-)
Edited by - kirkh on 10/31/2002 09:04:34
