 Fell in LOVE with the WB C-250!
Captdon
Initially Posted - 02/28/2010 :  21:02:34  Show Profile
I've always had a prejudices toward water ballasted boats, but after being on a C-250 WB today we're sold! So we're actively looking for one within 1000 miles of San Diego. What a great boat! This will be our 3rd Catalina boat,(Catalina-22 and our current Capri-18). Even the wife was in love with the C-250 with the space compaired to our Capri-18.
I know it's out there.......
Don
Response Posted - 03/01/2010 :  05:01:46  Show Profile
Hi Don,
Water ballast took a lot of criticism when it was introduced. Part of that of course is the kid all ready on the block defending his turf. However, there were some justifications. Water ballast requires harder chines (a flatter and wider bottom to add righting arm) and the hull forms simply weren't fully understood. They produced excessive yaw when heeling, which required more rudder control. Almost every manufacturer was caught off guard with an inadequate rudder leaving the boats to round up too easily.
The result was an initial stigma that as always lingers around. Adequate rudders and reefing discipline solve the rounding up and make the boats work. The advantages of a large enough boat to coastal cruise but easily trailer are a reality in a reasonably good sailor when the disciplines are adhered.
An unforeseen plus is that the water ballast has a character somewhere between a full keel boat and a center keeler. Center keelers themselves suffered a lot of criticism about their hobby horsing and poor rides in a sea way but there weren't that many who were sailing in a sea way anyway so the virtues of the center keel were appreciated and the poor ride in the occasional seaway was endured.
On the Great Lakes, center keelers often hole up and wait for better conditions while the water ballast ventures out for just another passage, handling the seaway with her unforseen virtue.
Response Posted - 03/01/2010 :  08:01:27  Show Profile
Hi Don... Do you plan to trailer her? Will she live in a slip or on a mooring most of the time? If the latter, have you compared the wing keel version to the WB? Each has its advantages--the most obvious probably being trailerability (WB) and headroom (Wing).
Response Posted - 03/01/2010 :  08:13:22  Show Profile
http://sandiego.craigslist.org/csd/boa/1619779567.html
Captdon
Response Posted - 03/01/2010 :  08:33:05  Show Profile
We've looked at both vervions, and really like the WB version because we intend to trailer the boat, and dry sail her as we currently do with outr Capri-18. A WK is not out of the question, but either way, we also would really like the Edson wheel system. I've been in contact with the one listed on CraigsList locally. I know the wheel is more complicated, and more weight in the stern, but it would be easier for my 1st mate to take the helm,(or guests onboard), and dang, if they don't look nice with that wheel!
Don
Response Posted - 03/01/2010 :  08:53:30  Show Profile  Visit britinusa's Homepage
I'm with you Don.
I presume you meant 'Day Sail' rather than 'Dry Sail' (Catalina recommends never leaving the water ballast empty on the water)
Looking forward to your lauch Pics.
(Welcome to the forum)
superbob
Response Posted - 03/01/2010 :  09:10:32  Show Profile  Visit superbob's Homepage
There's a 250/WB in Texas - - - http://www.sailingtexas.com/scatalina250117.html
Wind Toys in Santa Rosa CA - a Nor Cal Catalina dealer - had a WB in great condition&fully equipped a month or so ago: 707-542-7245. or 800-499-7245. Ask for John (the owner).
A used 250 in great condition, whether WB or WK, is hard to find. Good luck.
Captdon
Response Posted - 03/01/2010 :  09:25:58  Show Profile
Yes, seen the one in TX, was talking with the owner for a week or so. I was concerned by the WB, so I wanted to see one first hand. We went out with a couple yesterday and fell in love with the WB, it was much better than I imagined. So we decided to call the guy back in TX to buy it, and he's already got somome interested in the boat. So we're looking again, we know there is one out there somewhere....
Don
JimB517
Response Posted - 03/01/2010 :  13:14:54  Show Profile  Visit JimB517's Homepage
Charlie, Sterngucker on this board, is selling his. He sails out of San Diego and the boat is in Ridgecrest, CA (by Edwards AFB). PM me for contact info.
Charlie's is like new and with lots of extras.
Response Posted - 03/01/2010 :  13:19:05  Show Profile
<br />...I presume you meant 'Day Sail' rather than 'Dry Sail'...
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">"Dry sailing" is a common term for keeping the boat out of the water...
Don--if you plan to trailer-sail (dry-sail) the boat, have you experienced the set-up and break-down procedure for the mast and rig? It's doable, but it's not like your 18-footer.
Captdon
Response Posted - 03/01/2010 :  13:50:42  Show Profile
Yes, we "dry sail" our Capri-18, it's kept fully rigged and we have a lifting harness from the keel to lift and drop her into the water. We only break-down the boat a few times a year now. The C-250, with the mast raising system, looks pretty similar to rig like our Capri. I can't see it being that much harder to roll the mast back to fasten the base down. Once the mast is up, it seems pretty much the same, with the boom being a bit longer, but still manageble. Of course the C-250 will require a strap harness that some of the boats at the club use, to lift from the bottom of the hull. We have guys with 30'+ boats at the club that lower their mast to get under the bridge at Mission Bay. If they can perform this task using their boom as a gin-pole and their mainsheet while underway, I can't see it being that difficult to rig the C-250 while sitting on the trailer.
Don
Captdon
Response Posted - 03/01/2010 :  14:07:36  Show Profile
JimB.....Thanks for the lead. I couldn't get your e:mail. I've got my contact information in the "Swap Meet" section under WANTED: C250 WB. Thanks!
Don
Response Posted - 03/01/2010 :  16:19:05  Show Profile
Don, if you click the button on the header for Jim's post, you'll be able to send an e-mail to him, and your address (in your profile) will become the "from" address.
If you're leaving the boat rigged and launching with a crane, the wing keel would seem to be a viable option. The WB is best for ramp launching, and reduces overall trailering weight.
Edited by - Dave Bristle on 03/01/2010 16:19:25
Bob Jack
Response Posted - 03/01/2010 :  17:18:59  Show Profile
I'VE GOT ONE !
Did you say 1000 miles or 2000 miles away from California...maybe we could use UPS ?
Good luck...they're great boats .
Bob
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=17988&SearchTerms=NAPLES
JimB517
Response Posted - 03/01/2010 :  17:39:01  Show Profile  Visit JimB517's Homepage
Don, I sent you an email via the formum and invited you to sail with me any time. I am just under that bridge you talked about in Mission Bay.
Captdon
Response Posted - 03/01/2010 :  19:18:18  Show Profile
Bob....Nice looking C-250, but just too far away in Fla. plus, we really want the Edson wheel system.
Don
Captdon
Response Posted - 03/04/2010 :  11:53:39  Show Profile
Just wanted to thank everyone for responding. Hopefully we'll be C-250 owners soon! Thanks for the leads! This site has been awesome in helping us make our decision.
Don
Response Posted - 03/04/2010 :  12:41:35  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Captdon</i>
<br />This site has been awesome in helping us make our decision.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">This association (then with a sub-forum on trailersailor.com) was a key factor in our choice of our then-15-year-old C-25. This, Catalina Direct, and the continuing viability of Catalina Yachts, are a combination that very few boats, if any, can match. Some of us alumni can't break ourselves loose from the family. Too bad I can't get much help here with my hydraulic steering system...
Response Posted - 03/04/2010 :  13:27:04  Show Profile
<br /> Too bad I can't get much help here with my hydraulic steering system...
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I'll help ya Dave. Get a bigger hammer! That fixes everything.
Response Posted - 03/04/2010 :  20:28:32  Show Profile
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Bristle</i>
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...Get a bigger hammer! That fixes everything.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...the USAF way!
Response Posted - 03/05/2010 :  06:44:40  Show Profile
Aim High! ..... and miss the target
