 Upgrading mooring cleat
yamahapacifi
Initially Posted - 03/18/2010 :  16:31:17  Show Profile
Hi all,
We acquired a mooring for our 250 last year. The factory mooring cleats are too small to accept the pennant line (3/4" thick) legally required for the 250.
We came up with a hack solution last season involving the bow-eye (it wasn't pretty but it worked) but this year we'd like to upgrade default cleats.
I was able to update the chocks (I just installed some new ones a few inches behind the existing ones) but am not sure how to handle the cleats.
It seems like the options are:
1.) Remove the existing cleats (which are glued to the deck with a strong adhesive)
2.) Find a different location (perhaps between the hatch and the font window)?
Thoughts?
Response Posted - 03/19/2010 :  11:33:31  Show Profile
If I were mooring for days at a time and leaving the boat, I would rig up an anchor bridle/snubber that attached to both bow cleats.
This diagram shows all chain rode, but you could adapt a snubber in many ways. With an all chain rode it is advisable to have some 3-strand nylon that can stretch and take some of the shock off the bow roller. If you make your own snubber you can use line appropriate for your bow cleats.
[url="http://www.bosunsupplies.com/snubber.cfm"]Here [/url]is more info on how to make one.
But I have not made an anchor snubber for my boat yet, and I haven't used moorings very often, so maybe others could give their input on the pluses and minuses of that kind of setup.
Edited by - JohnP on 03/19/2010 20:46:55
Jack Schafer
Response Posted - 03/19/2010 :  17:38:59  Show Profile
I have moored on our lake for 10 yrs. and have had no trouble with 1/2 inch mooring lines. Are you sure the cleats are only glued on? My cleats are through bolted to embedded bolts. Our lake gets very rough at times with wakes from power boats and heavy winds. Are you on a mooring Ball? I normally run separate pennants from the cleats to the bottom of the mooring ball and for extra safety run a pennant from the bow eye to the top of the ball. I just drape the eye of the pennant over the cleat snub them tight with short 1/4 inch rope to keep them from flipping off. I keep the cleated pennants slightly tighter than the safety line. Of course you need swivels at the Buoy.
SEAN
Response Posted - 03/19/2010 :  19:31:40  Show Profile
hey paul ,
I am on a mooring i use 2 5/8s lines to the cleats ..i had to make the
chocks bigger , the cleats were fine .
then a 3/4 safety line to the bow eye ..
one bad storm both 5/8 lines chafed through ..
the safety line was fine .
now if a storm comes i use a 4th chain back up ..to the bow roller ..
so far so good .
yamahapacifi
Response Posted - 03/21/2010 :  06:59:54  Show Profile
Thanks for the suggestions, all. Yes, the cleats are bolted, but when you remove the bolts you find that they are also adhered to the deck (probably epoxied).
Scroll to the bottom of this page and you will see our setup: http://www.portlandharbor.org/mooringappmaster.htm
So, our pennant is 3/4" 3-strand with a loop around the end - intended to be run through chocks to a (properly sized) cleat. Reducing the size of this line isn't an option (legally), but perhaps some alternate method of hooking up to the existing cleats would be acceptable.
Any recommendations for removing the existing cleats and installing larger ones?
Response Posted - 03/21/2010 :  08:58:48  Show Profile
Maybe I'm just a sloppy reader, but I can't find the part where it says the pennant has to be 3/4". In fact, it seems to specify everything EXCEPT the pennant diameter.
Have you talked to a few different inspectors? Maybe you can get a different opinion about adequate size/material/rigging that would fit your existing cleats.
Edited by - TakeFive on 03/21/2010 08:59:21
frog0911
Response Posted - 03/21/2010 :  11:28:35  Show Profile
Concur, the only specification is for the length not the diameter. Here in hurricane land, We used 1/2 inch from the chocks to the mooring. Our length was the same as yours (2.5 X). During hurricane season we added 1/2 chain shackled below the mooring ball with swivel at 2.5 X plus one foot then shackled to the bow eye. These were the Navy's requirements at Jax Navy Marina.
Edited by - frog0911 on 03/21/2010 11:29:24
