 crazy keel question
pwhallon
Initially Posted - 11/04/2002 :  13:59:30  Show Profile
hi gang,
I need to know the measurement from the bottom of the keel to the bottom of the hull on a fin keel model. Not to the keel stub, but to the bottom of the boat.
If the waterline draft is 4 feet, wouldn't the depth from the bottom of the boat to the bottom of the keel be something less than 4 feet?
Here is a picture, from the photo section of the forum, showing the dimention I'm looking for. I downloaded it and added the white lines in Corel.
I hope Tweety's owner doesn't mind me using his picture. It's a very good keel shot.
<img src="http://im1.shutterfly.com/procserv/47b2cf25b3127cce91e4501e1b3c0000001410" border=0>
Tweety is a cool looking boat.
MattL
Response Posted - 11/04/2002 :  15:01:02  Show Profile
Paul,
Set up a simple ratio problem Your height on photo is to the keel in photo as your actual height is to actual keel
Example say you are 6 feet even in the photo you are (OK I have a metric ruler here, but units will cancel out) 4.7 cm the keel is 1.8 cm
6 is to X
as
4.7 is to 1.8
6 * 1.8 = 10.8
10.8 / 4.7 = 2.3 about 2' 4"
That sound about right?
Matt/Brigitte Loeffler
E.C. Rider
Cat 25 86'
FK/SR _/)
[http://im1.shutterfly.com/procserv/47b2dc07b3127cce9c9d8c699bc90000005410]
jm
Response Posted - 11/04/2002 :  15:18:32  Show Profile
Paul, if you can wait until tomorrow morning, I'll have a direct measurement for you. My boat is on-the-hard - I'll just go down and measure it (bottom of the keel to the hull).
Watch for it tomorrow am, unless someone else posts a direct measurement prior to this. (not to discount your proportion/ratio calculation Matt ! ! )
Response Posted - 11/04/2002 :  15:49:07  Show Profile  Visit Champipple's Homepage
I was going to tell him to do the same thing based on LOA of the boat in the photo....
Duane Wolff
"The Flying Wasp"
C-25, #401 std,sk
<img src="http://im1.shutterfly.com/procserv/47b2d603b3127cce9f858f0ef3ef0000001010" border=0>
Response Posted - 11/04/2002 :  19:49:50  Show Profile
Looks like a clip from a new PBS series called <u>This Old Boat</u>
The guy is saying "how many of you have encountered the Catalina smile? Well today we're explore the causes and remedies of this . . . "
jm
Response Posted - 11/05/2002 :  08:57:01  Show Profile
The answer is
33"
pwhallon
Response Posted - 11/05/2002 :  10:07:34  Show Profile
Thanks guys,
Jm, I appreciate you taking the time to do a direct measurement for me.
My Algebra stinks.
I have a Catalina 250 wing keel trailer. The bunks are a lot higher up than on my old C-25 wing keel trailer.
I'm trying to figure out how much adjustment will be needed if I get a fin keel boat.
This helps a lot.
Thanks to all of you.<img src=icon_smile.gif border=0 align=middle>
