 Staggered Tiller Holes?
C25OBrien
Initially Posted - 04/28/2010 :  15:00:46  Show Profile
I have the old ones drilled in a straight line. I am purchasing a new tiller, is it worth it to get the new straps with the staggered holes?
There are two options at CD:
Tiller Strap U-Shaped C-25, C-250
http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=1146
Tiller straps single:
http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=322
Thoughts? My most challenging seas will be a journey will bo to Block Island from Greenport this summer. I broke the old tiller crossing LI sound last October in a Nor'Easter. Thank gosh that was all that broke, now I am much more diligent at
checking weather.
Thanks all, happy sailing
-Chris OB
Cool Yer Heels
1980 C-25 SR/FK L-Dinette
Sag Harbor, NY
Response Posted - 04/28/2010 :  16:10:11  Show Profile  Visit delliottg's Homepage
Chris,
I don't know how helpful this will be, but I broke my tiller last year which has the U-channel. It broke due to dry rot at my auto pilot pin socket, and the U-channel had nothing to do with the break.
If I were looking for a new tiller, I'd be more interested in a solid, laminated one, than the steel attachments to the rudder stock. I made a new tiller out of laminated plywood seated in the U-channel and now have a spare solid wood (non-laminated) tiller (bought off of this forum) with the SS straps which I've never used. I will however keep it on the boat from now on.
pfduffy
Response Posted - 04/28/2010 :  19:25:08  Show Profile
Last year, I broke my tiller by placing a downward force on the forward end of the tiller. It split right along the lamination where the holes were drilled in line. Not sure if the outcome would have been different if I had the straps with the staggered holes. I repaired the tiller last year to get me through the remainder of the season but bought a new tiller and the straps with the staggered holes. The old one will be cut a bit shorter, reinforced and kept onboard as a spare.
Response Posted - 04/28/2010 :  19:27:20  Show Profile
When I replace my tiller I drilled new staggered holes in the old plates.
Unsinkable2
Response Posted - 04/29/2010 :  05:44:24  Show Profile  Visit Unsinkable2's Homepage
Staggering the holes is advisable. If all the holes are in a single layer of the lamination, that layer will be the first to fail.
I had an old tiller handle that was delaminating, and fixed by regluing it with gorilla glue, and then drilling angled holes through the tiller vertically, and then gluing dowels into these holes. The holes were drilled to oppose one another, so one hole angled aftward, the next foreward, the next aftward, and so on. With the opposing angles on the vertical pins, it became "impossible" for the tiller layers to delaminate in that area, because the layers were pinned by dowels angled in this pattern:
This gave me two more years of excellent service out of that tiller, and it was tested in some pretty heavy weather without ever giving me a cause for worry. When it finally delaminated again, it was not in the area I'd pinned and glued, but in the end of the tiller that I hadn't pinned. That time I replaced it with a new handle.
Edited by - Unsinkable2 on 04/29/2010 05:48:55
Response Posted - 04/29/2010 :  08:57:21  Show Profile
Drilling stainless can be tedious, but staggered holes are a good idea. As for "U" vs flat straps, the "U" would definitely be stronger butI have never broken or worn out a flat strap pair on any boat I've owned in 40+ years. Stainless fittings are not the weak link in the tiller/rudder junction. When "strong" far exceeds any expected load, "stronger" is not an upgrade.
