 access to upper rudder mount
Lee Hunter
Initially Posted - 06/20/2010 :  15:13:46  Show Profile
Does anyone know where the inside access is to the upper rudder mount? We're having the boat painted and need to remove it. We got to the lower mount in the quarter berth, but couldn't figure out how to access the upper one.
Response Posted - 06/20/2010 :  15:32:31  Show Profile
You need to cut an access hole from the cockpit to get to the mounts for the upper gudgeon. Catalina Direct sells a kit.
[url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=315&ParentCat=83"]Upper Gudgeon Kit[/url]
The also rent the hole saw.
[url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=1045&
ParentCat=83"]Hole Saw[/url]
Response Posted - 06/20/2010 :  19:21:05  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Lee Hunter</i>
<br />...We're having the boat painted...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Welccome Lee!
Hmmmmmmmmmmmmmm... Care to elaborate on your reasons for painting the hull? Most of us would caution against that under most circumstances, but we're always willing to listen, discuss, debate, argue...
Response Posted - 06/21/2010 :  04:49:47  Show Profile  Visit Champipple's Homepage
You should be able to get up there via the quarterberth - its a tight fit
Edited by - Champipple on 06/21/2010 04:51:49
Delilah
Response Posted - 06/21/2010 :  05:16:54  Show Profile
Champ
You think you can get to it from the inside? That would be good. I will have to look at that next time I am on the boat.
I have been having the problem of my lower rudder mount pin slipping off the gudgeon at the worst times. I am not sure if it is bent down or exactly what is going on but I have to look at it.
Andy
skrenz
Response Posted - 06/22/2010 :  12:34:28  Show Profile
Well I tell you, you can get at it from the inside if you are a 4' contortionist midget with arms only 2" wide.
Response Posted - 06/22/2010 :  21:08:55  Show Profile
What kind of paint are you planning on using? Two-part polyurethane? That's the only kind of paint I'd ever want on my boat.
Response Posted - 06/23/2010 :  04:58:53  Show Profile  Visit Champipple's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Delilah</i>
<br />Champ
Andy
One of the two pintles should have a hole for a pin or a ring to go through it and keep this from happening. Without it, even a moderate swell while going downwind will push it up and out of the gudgeon.
As I mentioned before, the access is tight back there. I'm about 80% certain we could reach it. That was on a '78.
Happy D
Response Posted - 06/23/2010 :  13:59:11  Show Profile
I removed mine. It is a very tight fit but I got mine off.
Getting the new one on was a different kettle of fish.
I ground the old gudgeon flat. I welded 3, 5/16" nuts to the old gudgeon and fished it up inside using 1/4" line. Then I bolted the new upgraded gudgeon to it from the outside. Worked like a charm.
I have some backing plates if you want them.
Dan
Happy D
Response Posted - 06/23/2010 :  14:00:21  Show Profile
You could just grind the bolt heads off and wack the bolts through.
