 Question to internal halyard owners
Initially Posted - 07/24/2010 :  19:19:43  Show Profile
I was inspecting the mast hardware of our new-to-us C25 today and discovered it has internal halyards (from the factory.) I became slightly alarmed when I didn't see any turning blocks on the mast step - but I also noticed how low the halyards exit the mast.
As the halyards exit the mast only a few inches above deck - are they lead directly to/thru the deck orgainizers?
Response Posted - 07/24/2010 :  21:22:26  Show Profile
I felt the angle was too much and created a tripping hazard. I put turning blocks at the mast step and was pleased with the result, it led more fairly to the deck organizer as well. I replaced the exit boxes on mine so I would have new sheaves in the base of the mast. I also replaced the deck organizer sheaves with the ball bearing upgrade.
Response Posted - 07/25/2010 :  05:16:13  Show Profile
Thank you Frank, ugh, your photo shows this very well. I have no plate under he mast step for attaching blocks. I am/was concerned about the halyards chaffing on the organizers. All of the ball bearings, sheaves need to be replaced. Launching on 31-Jul regardless . . . the 2011 list is hereby initiated!
Edited by - OJ on 07/25/2010 05:17:59
Response Posted - 07/25/2010 :  11:51:53  Show Profile
I've got an '89 like Franks and I've had no problems with chafing or with tripping but if I had a mast plate like Frank did I would make the same changes. I don't notice any major problems with friction when hoisting or dropping sail but Frank's setup has to make things work smoother.
Remember, you can never be too safe.
Response Posted - 07/27/2010 :  11:04:05  Show Profile  Visit aeckhart's Homepage
OJ,
You can get the plate for attaching blocks at Catalina Direct. It attaches with the original 4 bolts/bolt holes holding the mast step in place. It opens a lot of possibilities including Frank's idea. I've run my two reefing lines and rigid vang control line back to the cockpit with blocks anchored on the plate. Also like Frank I changed the box sheeves from one to two ball bearing type sheeves. I was able to add a second jib halyard as a result and am considering putting my spinnaker halyard in the mast. The location of the internal wiring & conduit may prevnet this mod though.
Kip C
Response Posted - 07/27/2010 :  15:10:07  Show Profile
Any opinions on an internal topping lift?
Response Posted - 07/27/2010 :  19:38:57  Show Profile
Remember there is also wiring rambling around in most masts so the fewer lines inside the better. However, the 89s had conduit inside the mast so the internal column is much "cleaner" if you install a wiring conduit.
Response Posted - 07/28/2010 :  06:52:08  Show Profile  Visit DaveR's Homepage
I've got an 89 and no helper blocks for my internal halyards. Things work very well and I'm adamant about keeping a simple clean boat with less things to go wrong.
Response Posted - 07/28/2010 :  07:44:30  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DaveR</i>
<br />I've got an 89 and no helper blocks for my internal halyards. Things work very well and I'm adamant about keeping a simple clean boat with less things to go wrong.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">KISS!
However, I think turning blocks would also reduce the wear and tear on the exit blocks. Spoke with CD and the exit blocks they offer don't have ball bearings. I'm going to check around.
Response Posted - 07/28/2010 :  08:41:29  Show Profile
They should not have ball bearings. The general rule is a block that holds a static load should be a bushing block and blocks that merely direct running rigging should have ball bearings. Bearings concentrate the load on very small round surfaces, non bearing blocks spread the load over a much larger bushing surface. Ball bearings are not always an "upgrade".
Response Posted - 07/28/2010 :  09:46:46  Show Profile  Visit aeckhart's Homepage
1988 models also have a wiring conduit in the mast.
If you have the mast conduit, I see nothing wrong with a topping lift rigged through the mast. You will need to increase the number of sheeves at the mast head though. I now have four, two more than original. See past threads for sizes.
Regarding "simple and clean"...... the basic boat is a day sailer only. Even the options offered on the C25/250 did/do not make for a properly equipped sailing vessel that is safe in most conditions, racing or cruising.
Equipment additions can be added, with for-thought, so that the outcome is "simple and clean". Teh only limitation is how much you wnat to spend for the sailing you intend doing.
Response Posted - 07/28/2010 :  10:26:17  Show Profile
<br />They should not have ball bearings. The general rule is a block that holds a static load should be a bushing block and blocks that merely direct running rigging should have ball bearings. Bearings concentrate the load on very small round surfaces, non bearing blocks spread the load over a much larger bushing surface. Ball bearings are not always an "upgrade".
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Apparently the bushings in my exit blocks are just worn out. I get the feeling there is no bronze bushing in these sheaves.
Thanks again Frank . . . more proof that sailng is a life-long learning experience!
Response Posted - 07/28/2010 :  11:59:32  Show Profile  Visit DaveR's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Regarding "simple and clean"...... the basic boat is a day sailer only. Even the options offered on the C25/250 did/do not make for a properly equipped sailing vessel that is safe in most conditions, racing or cruising.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
True, but this particular addition does nothing to make the boat more seaworthy, as with many upgrades we talk about here. And in my opinion a clean clutter free boat is more functional and easier to sail than a crowded one.
