In my search for a trailer I found that lots of manufacturers don't have the measurements, or wont make a trailer for a C25. One of them that will is Fast Load, located in Florida. They make an all aluminum trailer, which is popular in a salt water environment. Any thoughts as to which might be better, aluminum, or galvanized. I know that galvanized will rust at welds and any new holes which you might drill.
Frank, If you purchase a swing keel C25 you will definitely want rollers, not bunks. I have yet to see an aluminum trailer with rollers. I have a steel trailer that has hardly any rust - so a galvinized would be very beneficial IMHO. I know you'll spend more for freight, but why not have Trail-Rite build one - as they have built thousands and thousands of trailers for Catalina? Maybe they could piggy back a trailer with a shipment of Catalinas going east.
OK. I am going to go against conventional wisdom here, but here goes.
I used to have an 18-foot Buccaneer that I bought in Ohio for sailing on lakes there. It had an aluminum trailer from a company called Trailex, somewhere in Ohio. You can find them on the Web.
THen I moved to Long Island, where I started putting the boat into salt water. That happened in 1978.
I have had nothing but trouble with the trailer up until the time I gave it to my son. The steel axle rusted away. The steel fasteners rusted. U-bolts dissolved. The springs turned into nothing but a pile of rust.
Any metal there that isn't aluminum was attacked by the salt water. The bearings? Forget it. I had to change bearings almost every year, because they would just freeze up, even though I was using those great bearing buddies that keep packing grease into the bearing.
So if you're going to use this trailer in salt water, I would definitely get a galvanized trailer. It will rust, but in my experience, they are much easier to maintain than aluminum in salt water. In fresh water, the aluminum trailers are fine.
And, BTW, I doubt that this manufacturer is going to make an all-aluminum trailer. The axles, wheels, bearings, bolts, nuts, u-bolts etc., will be steel.
The reason the steel had so much trouble on my aluminum trailer, I think, was because of cathodic corrosion that happens when you immerse two dissimilar metals in an electrolyte. Steel and aluminum, in salt water (a great electrolyte) mean that the easier corroding material will corrode. That was the steel.
