Anybody have any advice for using quick pins? I am planning on using them in alot of the connections on my boat that get disconnected when the boat gets trailered. Those clevis pins with the split rings slow me down.
I am going to use the quick pins with the push button that releases the ball bearings on the end. Not the spring loaded kind.
The reason I ask about this is purely mechanical and engineering oriented. I think I am fine in using them in areas such as the boom-to-mast connection, for example, since tha connection isn't under a large load as compared to the furler connection at the bow of the boat.
My question for that type of connection is two parts. If I use a quick pin for the furler connection (to connect the furler base/forestay shroud to the bracket at the bow of the boat....don't know what that bracket is called)
1) Will it handle the load? The guy at the marine store questioned the strength of the push button quick pin versus the solid kind with the spring loaded ball-bearings at the end because the push button kind are hollow. But, the push button kind do have the pin that goes down the center that engages and disengages the ball bearings, which in my mind as an engineer, helps out in the strength department. I s'pose I could be less lazy and try to find the load rating for the pins and research the tensions developed in the forestay of the C250, but I thought I'd try you fine people first. <img src=icon_smile_big.gif border=0 align=middle>
2) Under such a great load as the forestay load, can the pin "walk out" of the connection? Especially if the forestay load fluctuates. This was a concern of a sailor friend of mine. In my opinion, with the push button kind, since the ball bearings are hard fast when it is engaged, "walking out" would not be possible. I can see how it could possibly "walk out" if it were the spring loaded ball bearings, though.
Does anyone have any knowledge or experience with this?
Jim, With my C250 I use the quick -removal pins in all the places you've mentioned. I was somewhat concerned about the forestay-furler connection, but in 3 years have had no problem, with "walking", distortion, bending, or succumbing to presuure in any way. My experience has been all good. Now if I took the boat out in 30-40 knot winds I might rethink this, but in those winds I'd probably stay home and watch Oprah anyway!!!
I use a button type quick pin in all places except the forestay. With a CDI furler, there is no redundancy on a C250 for a forestay failure... if it fails...the mast is coming down. Using a quick pin there is "flirting" with disaster and not worth risking the safety of crew and boat.
Also run is a safety stay when cruising. In the past, its been a line from a spinnaker mast crane to the bow pulpit... in the last two years its been a running baby stay (a line from the mast at the spreaders down to the stem, slacked when tacking).
I use to use the quick pin, on the forstay, on the old Santana 21 I use to have. For all other locations I had a regular solid pin and intead of a ring, or, the horror of it, cotter pin, a sort of safty pin type thing that was made out of stainless steal. I havent been able to find this kind of safty pin for the catalina, but it was very cool on the old boat. I think there might be one of them in the west marine set of pins and cotter rings for big boats, the $20 box not the $10 one
Jim, thanks for the links, now how many of you use the quick pins and exactly where do you use them? Do you use the push button style or another type? I do not trailor but when I take her out for maintaince I would like any advantage of efficiently puting the rigging back together again, Steve Steakley
The quick pins sound like a great idea. Don't know why I didn't think of it; It just goes to show the collective brain works better than one alone. I do rember early on thinking the current system really slows us down in the launch and retrieval process, but I was focused more on speeding up the launch rather than the rigging. I don't remember this topic being discussed before, or maybe I was sailing! <img src=icon_smile_big.gif border=0 align=middle> <BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> thanks for the links, now how many of you use the quick pins and exactly where do you use them? Do you use the push button style or another type? I do not trailor but when I take her out for maintaince I would like any advantage of efficiently puting the rigging back together again, <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> I would add one additional question what size or do you know of a hardware list from Catalina which would list the various pins? My boat is a couple of hours away from me at this point so it will be difficult to visit for measurements. If anybody has any other time saving hints on rigging I am all ears or eyes I guess in this case.
If you are trailoring alot, you might check out the forestay quick release lever (Catalina Direct 4.32, at about $50). I use one on the forestay and one on each of the two forward shrouds. You never have to monkey with turnbuckles. Once you have them tensioned properly (I had to add a toggle) you just snap them down and insert the quick pin. I haven't found it necessary to loosen the upper or forward shrouds to raise or lower the mast. It takes most of the pain out of rigging.
Do you know if it would work with a roller/furler? I have a CDI.
Ray, I am not sure if there is a list that shows the pin sizes. If there is, that would be helpful. Otherwise, I can tell what I have measured on mine so far.....
