 cleaning cushions
wegman
Initially Posted - 10/20/2010 :  17:53:58  Show Profile  Visit wegman's Homepage
Greetings. I need to clean the cushions on "Tenacity". They are original, but are in excellent shape. I checked the search function and there seems to be a difference of opinion on whether a washing machine (even a commercial, front loading one set to the "gentle" setting") can be used. I will appreciate your collective wisdom on this. Are there any recommendations regarding which soap or detergent works best?
Thank you!
Jerry Wegman
C25 1989 SR/WK 5994
"Tenacity"
Response Posted - 10/21/2010 :  06:03:09  Show Profile
21 year old woven polyester fabric might not fare too well in a washing machine with the usual agitation. The vinyl bottoms and zippers would probably stand up to that, though.
I'd soak the covers with laundry detergent <u>overnight</u> in hot water in the washing machine with no agitation, spin them in the washer, and rinse and spin again with no agitation. When you see the color of the rinse water, you will know how much more you have to do to remove the accumulated dirt.
You could also treat the bare foam rubber with dilute bleach water and rinse with a hose outdoors to remove any mildew from the last century, and then drip dry them for a few months some place warm.
If agitation in the washing machine were to shred the wonderful, antique, brown plaid, disco-era cloth, replacement or repair will be expensive, but it would also be a time to celebrate <u>once again</u> the end of the disco era.
Response Posted - 10/21/2010 :  07:45:26  Show Profile
We used a Rug Doctor with an upholstery attachment and the cushions look like new.
Response Posted - 10/21/2010 :  07:49:47  Show Profile
I put one or two soiled covers in a washing machine, and they turned out fine. I was afraid the dryer might damage them, so I let them air dry, which didn't take long.
ckroll
Response Posted - 10/21/2010 :  09:37:26  Show Profile
I'm in the process of restoring an 81' whose covers are in pretty decent shape. I simply threw them in the washer and let them air dry. Seemed to turn out fine. With that being said though, I have not put them back in boat yet and subjected them to use. I guess time will tell...
Response Posted - 10/21/2010 :  14:01:23  Show Profile
If you do put them in the washing machine and everything comes out OK When you put them back in the boat, Get a can of Scotch Guard and spray them good. It really works in keeping them clean. Or you could try a garbage can/bathtub and Woolite and just soak them.
Edited by - islander on 10/21/2010 14:06:19
Response Posted - 10/22/2010 :  05:11:49  Show Profile
I vote for Rug Doctor with upholstery attachment. You should be able to do that without removing them from the foam.
ckroll
Response Posted - 10/22/2010 :  05:43:15  Show Profile
I would probably lean the rug doctor way as well had I not wanted to bleach the foam (to get rid of mold/mildew). Putting them back in exactly right was kind of a pain.
Stuff4Toys
Response Posted - 11/01/2010 :  18:28:02  Show Profile  Visit Stuff4Toys's Homepage
<br />I vote for Rug Doctor with upholstery attachment. You should be able to do that without removing them from the foam.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">My vote too!
PCP777
Response Posted - 11/02/2010 :  07:36:03  Show Profile
<br />We used a Rug Doctor with an upholstery attachment and the cushions look like new.
Question, this is the angle I was going to go with but I was afraid of losing the water resistant nature of the fabric, is this something I should worry about?
Response Posted - 11/02/2010 :  08:49:23  Show Profile
Buy a spray can of Scotchguard. (Just don't breathe the stuff.)
