I need to know who makes the forward hatch. Mine is leaking and I would like to replace the seal with an OEM gasket or something else. Has anybody done this? Who has some good ideas on what works and what doesn't last? Thanks.
Mark Lewalski C250WB #206 Safety Harbor, Fl (aka Tampa Bay)
Mark... if I couldn't find very similar to original, I'd order a new hatch gasket from Catalina unless the hatch has sprung or needs additional thickness.
There are two issues with the hatch... first, the anchor locker drain must drain properly. If leaves or dirt dobbers clog it... then water will fill the locker and overflow into the hatch.
Second, if the boat is kept on the trailer... the trailer pitch is important. It requires a degree or two up on the tounge. Less than that will allow water in the companionway hatch... too much will allow water in the forward hatch.
I actually use an angle guage from the home center. It has a magnetic base, with a gravity swung arm that points to a circular scale. I set it on the tongue when I stop for the night or otherwise park the boat on the trailer. It can also be used to check the ramp slope.
