 going to salt water
jnhiggins
Initially Posted - 04/03/2011 :  10:14:31  Show Profile
Hello all. I've been sailing my 250 wb (hull no. 167) on Lake Erie for the past 12 years. Now I'm considering taking my boat to Florida, where I currently spend winters. I'd appreciate any general advice on:
1. Finding a marina in the Tampa/St. Pete area.
2. What to keep in mind in making the transition from fresh to salt water.
Thanks in advance?
James V. Higgins
Tradewind
Response Posted - 04/03/2011 :  11:06:51  Show Profile
Going from Lake Erie to warm gulf coast waters will require a different bottom paint. Also it's a good idea to flush the motor with fresh water after each outing. Expect more corrosion and rust, requiring a little more maintenance, good idea to give the boat a fresh water rinse after each sail.
That's a beautiful sailing area, lots to see especially south towards Ft Myers.
Response Posted - 04/03/2011 :  11:39:57  Show Profile
Don't leave the dock without a chart or chartplotter, and check it frequently. There is a lot of skinny water there. A depthsounder is also a big help. It's one of my favorite cruising grounds. Beautiful!
Response Posted - 04/03/2011 :  13:55:44  Show Profile
<br />Don't leave the dock without a chart or chartplotter, and check it frequently. There is a lot of skinny water there. A depthsounder is also a big help. It's one of my favorite cruising grounds. Beautiful!
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Learn about tides, they make skinny water skinnier.
At Ease
Response Posted - 04/03/2011 :  15:05:34  Show Profile
When you get back after a sail, wash the boat...get the salt off of it.
zeil
Response Posted - 04/03/2011 :  19:44:26  Show Profile
1) Install, screw, some sacrificial zinc to the underside of your centerboard steel mounting hardware and 2) tape and run an insulated wire from the ballast tank closure fitting through the companion way to an overboard suspended zinc if you stay in an unknown and possibly "hot", marina for any length of time. The same goes for your up-haul mechanism
2) For bottom paint we use Interlux ablative CRC antifouling which we can assure you is good for both fresh and salt... but leaves a lot to be desired for staying on the hull.. (we have flake problems perhaps due to temperatures fluctuations and longer periods on the dry)
3) During our year-long living aboard our C250 WB round-the-continent trip we made Port Hudson, Florida sort of our home port for over 2 months. It was pleasant, central to a lot of things. The marina had internet, electricity and showers. It was economical and somewhat off the beaten path. Skinny waters are everywhere. Having a depth sounder and chart access is a must... we loved it and have great memories
Edited by - zeil on 04/03/2011 20:05:29
Response Posted - 04/04/2011 :  08:29:41  Show Profile
Establishing a method of conveniently flushing your outboard after each use will help in avoiding a clogged cooling system.
A check of your trailer for any non-galvanized metal would also be in order. Salt water is extremely tough on trailer components.
Response Posted - 04/04/2011 :  10:26:54  Show Profile
There are many marinas to chose from in Tampa/St Pete. And because of the economy, there are many slips available. Where in the area do you reside in the winter?
Tampa Bay itself is about 10'-15' deep in most places and once away from shore you do not have to worry about running aground. The mouth of the bay "Egmont Key" area has some shallow areas, so you need to keep a watch the depth sounder.
Response Posted - 04/04/2011 :  14:01:30  Show Profile
I haven't been there in years, but St. Petersburg Municipal Marina was nice, and well located in the heart of the Bay. It's probably pricey, but might be affordable seasonally.
http://www.stpete.org/marina/
jnhiggins
Response Posted - 04/05/2011 :  10:09:24  Show Profile
Thanks to everyone for the help. We love the St. Pete Municipal Marina and that is my first choice, although there's a long waiting list. Shallow draft should help us get a spot, though!
Jim Higgins
