 winch maintenance...
calden
Initially Posted - 04/14/2011 :  09:24:51  Show Profile
First sail of Spring yesterday, and got that grinding noise when sheeting in under load... did not happen last year.
I assume this means a standard winch maintenance, correct?
I am 1.5 hours away from the boat and won't be getting there for another couple of weeks. Can anyone tell me... what would have been the standard Lewmar single-speed non-selftailing winch on an '83 C25? (Isn't that silly - all the photos I've done and time I've spent and I can't identify the winch without being there, and I totally neglected to write down the model number...)
Carlos
S/V Mazama
1983 FK SR
#3682
Response Posted - 04/14/2011 :  10:13:21  Show Profile
From my observations, and what is on my boat, Lewmar 7's appear to be the standard winch.
pfduffy
Response Posted - 04/14/2011 :  10:14:24  Show Profile
My boat has lewmar 7's
calden
Response Posted - 04/14/2011 :  10:22:33  Show Profile
Thank you so much. That's what I kind of thought. I'll look for a maintenance kit.
Carlos
Response Posted - 04/14/2011 :  14:58:46  Show Profile
An old trick for working on winches... Cut a hole the diameter of the winch in the bottom of a box with an open top, and then slip the box over the winch before you start taking it apart. That way when a part goes "PING", it won't become property of King Neptune.
I also scaled the idea up for working on my outboard--had a box that fit where the cowl was removed.
Edited by - Stinkpotter on 04/14/2011 15:03:56
calden
Response Posted - 04/14/2011 :  20:49:44  Show Profile
<br />An old trick for working on winches... Cut a hole the diameter of the winch in the bottom of a box with an open top, and then slip the box over the winch before you start taking it apart. That way when a part goes "PING", it won't become property of King Neptune.
Thank you for the tip. Will do. I had already bought a box of spare Jesus clips to keep on hand.
Carlos
