 Rub Rail cleaner
treeder65
Initially Posted - 05/03/2011 :  14:40:26  Show Profile  Visit treeder65's Homepage
Does anyone know the best way to get the rub rail cleaned up a little bit?
Tom
1986 C25 SR/FK #5299
Hunterdon County, NJ
Edited by - treeder65 on 05/03/2011 17:29:36
Response Posted - 05/03/2011 :  16:21:01  Show Profile
Mr. Clean Magic Eraser, but hard scuffs tend to be ground in and refuse to be cleaned. Replacing it is pretty easy if you want the cleanest look.
Response Posted - 05/03/2011 :  16:42:15  Show Profile
M.E.K or Acetone worked really well for some of us. Soak a rag well and wipe the rail. Use hand protection.
Edited by - islander on 05/04/2011 14:56:48
treeder65
Response Posted - 05/03/2011 :  17:32:45  Show Profile  Visit treeder65's Homepage
Thanks for that info. I have MEK, so I'll give that a shot first. I am in the midst of wet sanding with a jitterbug pneumatic sander. I ran the 800 over the rail and it came out flawless in a matter of seconds. Thanks again.
Response Posted - 05/03/2011 :  17:39:30  Show Profile
Yep, our rubrail looked like it had dirt and/or mildew in the rubber. We tried a few household cleaners - including TSP - with unsatisfactory results. We then used MEK and it turned out like new. <font color="blue"><i>Observe the warnings about its use though - use gloves and don't breath the vapors. With the boat on its trailer, we stood on short step ladder so we had to reach up to the rub rail - keeping the vapors above our breathing zone.</i></font id="blue"> It will soften the rubber a little for a short period of time. You'll get the hang of it after cleaning the first couple/three feet.
Good luck!
Edited by - OJ on 05/03/2011 17:41:00
Response Posted - 05/03/2011 :  18:26:33  Show Profile
I use Goof Off. Has a million other uses too.
Response Posted - 05/03/2011 :  19:36:05  Show Profile  Visit britinusa's Homepage
That rub rail looks sweet OJ.
[url="http://www.ccohs.ca/oshanswers/chemicals/chem_profiles/mek/health_mek.html"]Canadian OSHA on MEK[/url]
Response Posted - 05/03/2011 :  21:30:33  Show Profile
I've become kind of a fan of Collinite products, and found that a little rub-down with liquid Fleetwax removed the marks, restored the color, and kept the vinyl rail (as well as the hull) looking good for the season.
This year on my challenging dark green hull and black rubrail, I'm trying out Collinte's #845 Insulator Wax, which was highly rated by Practical Sailor. It has no cleaning or abrasive properties--it's just wax. But the process is easy--wipe on, let it haze over, and then rub lightly to a shine. My dark hull is a good test for protection--we'll see whether P/S got this right.
(O/T Note: I have recommended Poly Glow here, but that was for aging hulls. My current "pot" is entering its fifth season out of the factory. I'll continue tryng to keep the gelcoat looking good with some rubbing and wax, and might go back to a polymer finish, which is a little more like varnishing the hull, some years down the road when she's a little more aged and tired.)
treeder65
Response Posted - 05/04/2011 :  03:29:33  Show Profile  Visit treeder65's Homepage
Be careful with Goof-Off(xylene) also:
http://www.ccohs.ca/oshanswers/chemicals/chem_profiles/xylene/health_xyl.html
i can attest to the loss of short term memory and anxiety. I use xylene in my line of work.
Response Posted - 05/04/2011 :  07:24:34  Show Profile
Has anyone else (except CateP on Mysterious) replaced the rub rail with a wood one?
Renzo
Response Posted - 05/04/2011 :  07:59:05  Show Profile
I agree with the use of acetone it does the job quick and easy. (Don't care for MEK or Goof-Off because I seem to be highly sensitive to the vapors.) For the last few years I've been following up the cleaning of my rub rail with an application of Armor-All. It's Makes it look like new and seems to make it easier to clean the next year.
Response Posted - 05/04/2011 :  14:56:04  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Don't care for MEK or Goof-Off because I seem to be highly sensitive to the vapors<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
You can use either one, They both get the same results but MEK has a slower evaporation rate than Acetone so I would guess you wouldn't have to load the rag so often. Nether one smells like roses
treeder65
Response Posted - 05/04/2011 :  17:46:58  Show Profile  Visit treeder65's Homepage
Hands down MEK IMO after trying both xylene and MEK today. Same results but MEK was about 5x faster. I did the whole rail in 15 minutes.
Response Posted - 05/05/2011 :  05:43:10  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by treeder65</i>
<br />Hands down MEK IMO after trying both xylene and MEK today. Same results but MEK was about 5x faster . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Someone here recommended MEK last year, and someone else posted the link for polishing gel coat - both resulting in what you see above. All these contibutions make this forum the great site that it is . . .
Renzo
Response Posted - 05/05/2011 :  06:43:37  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by islander</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Don't care for MEK or Goof-Off because I seem to be highly sensitive to the vapors<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
It's not the smell, It's the Broncial irritation that I object to. But I may just be more sensitive to it than others.
Edited by - Renzo on 05/05/2011 06:46:55
Captain Max
Response Posted - 06/16/2011 :  09:51:49  Show Profile
Someone mentioned replacing the rubrail, got me wondering. Can you get different colors for the rubrail?
Response Posted - 06/16/2011 :  10:56:19  Show Profile
I believe Catalina Direct sells grey or tan.
Response Posted - 06/16/2011 :  12:24:12  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Captain Max</i>
<br />. . . Someone mentioned replacing the rubrail . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">And someone else mentioned what a big PITA replacing the rubrail can be . . .
Response Posted - 06/16/2011 :  20:04:37  Show Profile
The old rubrail insert just peels out of the aluminum channel. Get the same cross section shape at WM or your supplier of choice in your preferred color and it isn't bad to put the new stuff in once you get the it started.
Response Posted - 06/16/2011 :  21:06:20  Show Profile
I've heard soaking it in a bucket of warm/hot water will help it be more pliable and slide in to the track easier. Never done it before so take the comment with a grain of salt.
