 Mainsheet blocks
BernieM
Initially Posted - 06/03/2011 :  07:01:28  Show Profile
I'm thinking about replacing my old, worn out mainsheet blocks and I was wondering if anyone has a suggestion on what to use. I've looked at the kits that CD sells, and the Harken carbo set looks pretty nice. Anyone tried these or are there better options somewhere else? My current fiddle block with cam cleat is very hard to release which makes sheeting out a real pain. It is definitely a two handed job to release and recleat, which isn't optimal considering I don't have a third arm to handle the tiller.
Bernie
1983 C25 TR/FK #3501 "Songbird"
Sailing on Atwood Lake, Sherrodsville, OH
Response Posted - 06/03/2011 :  08:11:24  Show Profile
Those things aren't cheap. I need a boom vang, and the cost of building my own is the same, or more, than the one from CD simply because that fiddle block with Beckett and cam is so dang expensive.
Can you take yours apart, clean it, or replace anything worn out? I did that with my traveler car, and polished the tube....made my traveler work like new.
Response Posted - 06/03/2011 :  08:27:35  Show Profile
Harken or Garhauer, either one is good. I prefer the Harken Carbo Airblocks, but if you do not race seriously the standard harken blocks work very well. Actually, I have a spare main sheet/boom vang tackle that I was going to hold for use with our A-frame. I think it is Harken. I'm going to the boat today, so I'll get it and take a pic for you. Haven't thought about a price yet since I just read this thread, so I'll have to give that some thought. I know it has a fiddle block with cam, maybe a becket too, but I can't remember if it has a single or fiddle block on the other end.
Also, can you change the cam angle, looks odd in the pic above.
You might also check Ebay for fiddle blocks and boom vangs. There's a vang offered with spintech blocks for about $88.
Edited by - dmpilc on 06/03/2011 08:44:25
sfsmith
Response Posted - 06/03/2011 :  08:40:38  Show Profile
Mine was jamming at times and, even worse, releasing on its own. I took the cams apart, cleaned about a pound of spider webs out of each one, lubricated them with Teflon spray and reassembled them. Not exactly like new, but they work much better.
Response Posted - 06/03/2011 :  09:02:02  Show Profile
It sounds like your issue is with the cam cleat and not the blocks. I'd imagine you could replace that for a whole lot less than new blocks. Do the sheaves spin freely when they're not under load? Once you have the cam released, do you still have problems sheeting? If not, I'd bet the problem with the blocks is purely a cosmetic one.
BTW, do you pull and lift when releasing the cams or just try to lift the line straight up? If pulling on the cam doesn't open them, you probably need a new cam.
Response Posted - 06/03/2011 :  10:25:21  Show Profile
My fiddle block is set up so a downward pull releases the line with a horizontal and above pull setting the sheet. Looking at your block, it appears to be set up so you need to pull mostly upwards to set the line?
Edited by - dlucier on 06/03/2011 10:36:48
BernieM
Response Posted - 06/03/2011 :  10:26:50  Show Profile
Are the cam cleat replacements mostly interchangeable? I tried finding the brand marked on the fiddle block, and I wasn't able to find anything.
Once I finally get the sheet released from the cams, it seems to sheet in and out freely, so I suppose the sheaves are fine.
John: I have to pull and yank downward on the sheet to release from the cam.I am able to sheet in while it is engaged in the cam cleat, so I guess it still halfway works-just not well.
I'll try taking them apart this weekend and see if I can get it freed up any better. I just started racing this season and it was pretty irritating trying to make adjustments.
Do the more expensive blocks provide a noticable performance enhancement, or is it brand/cosmetic appeal that makes it so expensive for those carbo airblocks?
Response Posted - 06/03/2011 :  11:19:55  Show Profile
I buy blocks on ebay. Mainsheets and vangs should be Harken, the adjustablility of the cleat angle is critical and Harkens do that very well. Ratcheting is a nice touch but does not really matter. What you have now is an odd ball POS, make sure you stay with standard fiddle blocks. Garhauer cleat angles are not adjustable, stay away from Garhauer for purchases, it is an OK brand for single blocks but are really made cheaply. I had to settle for a Garhauer genoa car on my new boat and it is cheap crap.
Response Posted - 06/03/2011 :  13:17:02  Show Profile
Nice to know I'm bidding against good company on ebay . . . I think
Response Posted - 06/03/2011 :  14:41:14  Show Profile
I checked the spare block & tackle on my boat. It consists of 2 aluminum Schaefer Series 3 fiddle blocks, in like new condition, one with cam and becket, both with snap Shackles. The cam is not adjustable. They are worth $225-250 new. I would want $175.
Quite frankly, I agree with Frank that you would be better off getting a Harken fiddle/becket/cam block. With the forward sloping angle of the mainsheet, you really do need the adjustable cam.
Also, check this out on Ebay, a Scheafer fiddle with cam & becket for $73.00 "Buy It Now" price. might work for you:
http://cgi.ebay.com/ebaymotors/Schaefer-Aluminum-Fiddle-Block-w-Adjustable-Cam-Becket-/250827830618?pt=Boat_Parts_Accessories_Gear&hash=item3a6680f55a
Edited by - dmpilc on 06/03/2011 14:51:54
Response Posted - 06/06/2011 :  10:06:40  Show Profile  Visit Champipple's Homepage
Take a look at defender.com They have some lewmar triple and double 50 and 60 mm synchro (brand) blocks that will handle 3/8 line and the cost is reasonable. We put triples on the old c-25 and the main sheet worked like a charm in heavy air at 5:1. In really light air we took the line off some of the sheaves and ran at 3:1
BernieM
Response Posted - 06/07/2011 :  14:44:56  Show Profile
Do the lewmar blocks have the adjustable cam angle similar to the harken?
