 c 25 windows leak
goran
Initially Posted - 06/16/2011 :  07:03:32  Show Profile
Hi Catalina 25 86' windows leak how to fix it what to used between windows and fiberglass
Response Posted - 06/16/2011 :  07:52:29  Show Profile
The sealant I used is called Dow Corning 795.
Here is a link to the thread. I actually replaced the windows.
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=23031& SearchTerms=finally,new,windows
If you don't want to remove the windows you can use a "flow-able" windshield sealant that is available at auto parts stores. It worked well for me until I decided that I wanted to replace the windows.
Edited by - Davy J on 06/16/2011 07:57:49
frants
Response Posted - 06/20/2011 :  11:05:31  Show Profile  Visit frants's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by goran</i>
<br />Hi Catalina 25 86' windows leak how to fix it what to used between windows and fiberglass
Hi Goran,
I can recommend Don Caseys book: "Hull and Deck Repair" lots of good advice. You may need to take the window apart and re-assemble with the proper sealants. not too bad of a project, just be sure that the window is back in before you hit the big waves...:-)
frants
