Has anyone upgraded the forward cleats on their 250?
I use a 1/2 anchor rode and 1/2 docklines, and when rafting up with other boats the original cleats on my 1998 are just not large enough to handle both.
Is there a larger cleat with the same footprint?
Brad Wagner C-250 Wing Keel #361 Lake Pleasant, AZ
Brad the replies column tells it all...I have a c25 and also use oversized lines and the cleats were always a concern as you mentioned...The need for a set of cleats amidships is another bother. Problem is a lack of motivation to push that item to the top of the to-do list.
Why are you using such large lines on your C-250? 3/8" lines are better-suited for a boat of that weight, and the boat's weight is insufficient to make 1/2" lines stretch as much as they should. The stretchiness of nylon lines cushions and protects your boat from developing hairline crazing in the gelcoat around the cleats. Jacque Cousteau once anchored "Calypso,"(a converted WWII mine sweeeper)in the mid-Atlantic on a 3/8" nylon anchor line several miles long. It has ample strength to hold a C-250.
Our sailing club rafts up on a regular basis. Sometimes we have as few as 10 boats up to as many as 42 in a sunflower. With the loads that get applied 1/2" is necessary.
