 Seaward Princess Stove Parts
irishsailor321
Initially Posted - 06/26/2011 :  11:06:28  Show Profile
Looking for the rubber(?) seal that goes on the plunger that is used for pressurizing the stove.....Also looking for a new cutting board. Anybody got an old Princess (stove, that is) laying around I might be interested in buying the whole thing.
Aboard the sailing vessel ''Simple Pleasures'', Kerr Lake, NC
PZell
Response Posted - 06/26/2011 :  12:27:36  Show Profile
If you can get it apart take a good look. I have a feeling that the seal that plunges up and down to create pressure is leather. You might be able to make one. If you mean inside the cap, then check a hardware store for a rubber washer. I'm guessing about your problem. But here's a couple of ideas for you.
Response Posted - 06/26/2011 :  14:10:37  Show Profile
You might try these guys -->> http://www.rvdealership.com/rvdstore/index.aspx?CustomerNumber=885555
What model is your range?
irishsailor321
Response Posted - 07/13/2011 :  11:53:32  Show Profile
I found it....A&H in California has parts for the old Seaward cookers!
