 Length of Screw/Rivet for Mast Ring???
jfesi
Initially Posted - 12/15/2002 :  14:19:19  Show Profile
I'm a little nervous as I've never drilled into the mast or boom. I'm adding a whisker pole ring onto the front of the mast and will probably borrow Father in laws new rivet gun. Question I'm wondering about is proper size of rivet/screw. Width isn't as big a question, but what about length? Could it foul any interior lines within the mast? I know many folks have added rings and tracks, so I'm sure I shouldn't be to worried. Lastly, is rivet preferred method over traditional screw which raises another question, if screws, should they be self tapping? Thanks for any input!! Happy Sailing and Happy Holidays
Response Posted - 12/15/2002 :  23:29:33  Show Profile
Either will work...
Fine thread screws may be better than course...
I like rivets... but the larger sized stainless rivets take a healthy rivet tool...
The pvc conduit in the mast is off center slightly so as not to interfere with adding rivets/screws in the forward center. Rivets should be sized between .125 and .250 inches beyond the wall of the mast.
Tracks are often put on with screws rather than rivets because they are pre countersunk for flat head screws.
If using screws, the holes should be drilled and tapped. Only the proper size bit for a given tap should be used.
In salt water environment... stainless to aluminum fasteners require an anti corrosion agent.
I would say, if mounting a track...use screws, if mounting an eye that doesn't have countersunk holes, use rivets but ensure that the tool is a healthy one. Riggers will have a hydraulic riveter but a heavy duty mechanical one will work ok.
<img src="http://www.cox-internet.com/arlynstewart/images/helming.jpg" border=0>
Arlyn C-250 W/B #224
R&R N/E Texas and Great Lakes
Edited by - arlyn stewart on 12/15/2002 23:34:35
jfesi
Response Posted - 12/15/2002 :  23:59:46  Show Profile
Thanks Arlyn, appreciate the input regarding the whisker pole ring, will be out on deck this week. By the by , great website you set up.
Tropical Sleigh WB619
Response Posted - 12/18/2002 :  11:43:46  Show Profile  Visit aeckhart's Homepage
Arlyn,
Great photos of the mods on your C250. I am particularly interested in the gin pole. Do you know if Catalina makes these for the C25T? I'm currently using a 2x4, which works ok but the addition of the winch will really help out. What a great idea. I had planned on trying the winch on my trailer. The aluminum pole would be cosmeticly nicer but....
Also, I could be wrong but I believe your barber haulers are also called "twing lines" in racing circles. A little trivia.
Al
GALLIVANT C25T #5801
Response Posted - 12/18/2002 :  15:50:52  Show Profile
Thanks Al, Twings strikes some remembrance of what Charlie called them....
Yes, I think an Aussie came up with the idea of putting the winch on the gin pole and marketed a pole... but as easy as one is to build, I doubt if shipping to US would find much market.
Their pole used a saddle and a strap to fasten near the base of mast.
If I were starting from scatch, I would use the Huntington rig outlined in the tech section. Its an A frame gin pole so has no need for lateral bracing (on the gin pole) and I believe secures easily to stanchion bases.
You could however, put a winch on one of the A frame legs of the Huntington gin pole. Doing so would put the operator out of harms way compared to using a sheet winch.
Edited by - arlyn stewart on 12/18/2002 15:54:06
Edited by - arlyn stewart on 12/18/2002 15:55:06
