 Need bow lights- suggestions?
Michael Meyering
Initially Posted - 08/26/2011 :  09:09:38  Show Profile
I want a bow light that mounts on the pulpit (for greater vis), and all other lights. C-82. Preference is 2 nm LED.
thanks!
Jesus is the Lifeguard of the world
Edited by - Michael Meyering on 08/26/2011 09:10:03
Response Posted - 08/26/2011 :  09:47:37  Show Profile
http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=284&ParentCat=161
Response Posted - 08/28/2011 :  08:55:42  Show Profile
I have this fixture on Passage. I installed a Dr LED white light in it, and noticed it was considerably dimmer than using a regular incandescent bulb. According to the literature, this configuration does not meet the USCG 2nm visibility requirement. Apparently, when the white light passes through the lens, it radically cuts the light output.
There are several purpose-built, LED-based red/green fixtures available on the market. This type combines a red LED and a green LED side-by-side that sits inside a clear fixture, rather than a single white LED inside of a red/green filter. I can't say how well this type works as I opted not to go with this approach.
Response Posted - 08/28/2011 :  11:00:49  Show Profile
The USCG does not approve <i>any</i> LED bulb for replacement of a different bulb in a running light. They only approve the fixture/bulb combination as it comes from the manufacturer. Bruce's experience shows why.
Response Posted - 08/28/2011 :  13:55:52  Show Profile  Visit delliottg's Homepage
Look into [url="http://www.imtra.com/product/marine_lighting/led_replacement_bulbs/fit_navigation_fixtures/festoon_navigation_anchor_stern.htm"]Imtra LED lights[/url], they make bulbs in specific wavelengths depending on it's use. I replaced my bow, stern, & steaming lights with them, and they're quite bright. My anchor light is a Dr. LED which I replaced about a year ago.
For the Imtra LEDs, you use the "warm" bulbs for your red/green running lights, and the "cool" for everything else.
From their website:
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><font size="2">This high output LED cluster festoon style bulb easily exceeds the brightness level of the 10W incandescent bulb it replaces. It has panels on five different planes, each containing 6 SMD LEDs for a total of 30 LEDs delivering crisp white light beyond 3 nautical miles. The dimpled barrel end contacts are made to fit the popular Aqua Signal Series 25 navigation lights. It replaces the 12V festoon bulb #ASL-902007 or the 24V #ASL-902017. This cool white version is very effective in mast-head and stern light fixtures but not recommended for red/green navigation lights (see our warm white version for this application).
Navigation lights are tested and approved as a fixture with the original equipment source (bulb) already installed. The operator of vessel assumes all liability when using this product as a replacement for the original approved light source. The use of this LED light source in individual navigation fixtures has not been evaluated for compliance to USCG, COLREG, or any other navigational lighting standards or regulations.
</font id="size2"><hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
And as Dave pointed out, these are not USCG approved because the USCG does not approve bulbs alone, only entire fixtures.
Edited by - delliottg on 08/28/2011 13:57:24
Response Posted - 08/29/2011 :  03:41:14  Show Profile  Visit OLarryR's Homepage
USCG approved LED bow light fixtures w/2nm distance:
Check out Lopolight website, OGM Orcagreen website and Aqua Signal's new LEDs at their website. Lopolight - I like their design and I have the OGM LED anchor light but these mfrs are very expensive. I believe the Aqua Signal Bow Light is much more resonable in cost. Here is the Aqua Signal link:
http://www.aquasignal.info/us/ecat/htdocs/index.php?category_id=1& subcategory_id=1& product_id=38& item_id=7
Here is one distributor of the Aqua Signal 32 LED Bow Light:
http://www.go2marine.com/product.do?no=155724F
The Lopolight and OGM bow lights, I believe are more than double the cost of the Aqua Signal LED fixture. However, all three are USCG approved for 2NM.
I really like the design of the Lopolight but here is an example of the enormous cost difference between the Aqua Signal LED fixture and the Lopolight fixture - Here is one distributor for the Lopolight fixture:
http://www.pyacht.com/lopolight-2nm-bow-light.htm
Edited by - OLarryR on 08/29/2011 04:17:56
