 Swing Keel is stuck up Catalina 25 1983
tc_gill
Initially Posted - 09/11/2011 :  20:22:16  Show Profile
While towing a pontoon boat, we were rocked hard by a speed boat coming into our marina. Horrible noise resulted, I thought from the keel.( Not to mention all the spilled stuff in the cabin.) We had the keel all the way up to go to a beach. It has a new cable and we also installed the shims to keep it stable when down. Now, keel will not fall down. The cable is loose when let down. We have kept it locked up. Got any ideas?
Terry
Edited by - tc_gill on 09/12/2011 04:04:17
Response Posted - 09/12/2011 :  05:40:53  Show Profile
Does your marina have a <i>no wake zone</i>? Did you get the registration number of the speed boat? Knocking items off your shelves is a pretty damn big wake.
The safest way to figure why the keel won't move is on a trailer, cradle or boat stands.
Response Posted - 09/12/2011 :  06:30:25  Show Profile
Not knowing how your shims are installed, it sounds like one of them was turned into a "jam". Can you get a quick lift at a marina?
Lee Panza
Response Posted - 09/12/2011 :  07:12:47  Show Profile  Visit Lee Panza's Homepage
Considering the weight of that slug of cast iron, it's unlikely that binding at the pivot alone would prevent it from dropping. If the keel and the trunk were heavily encrusted with barnacles and/or mussels the jostling might have been enough to jam it a little higher in the trunk than what you had thought was the top of its travel.
A likely candidate for the primary cause, however, would be the turning ball where the hoist cable enters the tube from below: some owners have discovered that the ball had stopped rotating, and raising/lowering the keel had worn a deep groove in the ball that was binding the cable. If it had progressed to the point that it was about to seize, the jostling might have aggravated it enough to finish the job. It's also conceivable that the keel was raised so high that the fitting at the end of the cable became jammed in that groove when the boat was bouncing.
It may be possible to look down the tube with a small mirror and flashlight. If the cable is slack around the ball you might be able to rule this out. However, if the ball or the fitting are the primary factor it'll have to be fixed on the hard; even just a kink where the cable goes into that fitting would substantially reduce the strength of that critically important cable.
Like OJ, I'd strongly advise you to haul the boat and play with it on the hard, with support under the keel to prevent it from dropping very far once you do dislodge it.
Good luck.
Response Posted - 09/12/2011 :  11:08:27  Show Profile
Definitely do it on the hard. It is difficult to jam a keel at the pivot end, the fulcrum of a lever, do to the extremely high loads involved, but not so difficult at the lifting end since the pivot carries almost half the weight when the keel is retracted. Put it on the trailer or stands because it may take a little while to fix it
tc_gill
Response Posted - 09/12/2011 :  11:17:23  Show Profile
Thanks so much for all the ideas. We are looking for a trailor now. Lake is dropping quick and we don't have much time. We want to sail!
