 Boat fell
Initially Posted - 10/11/2011 :  10:16:54  Show Profile
I was hauled out yesterday. The yard guys parked the boat in its winter resting place, lowered the wheel on the tongue, chocked the tires and left. A little while later, I was on board cleaning things up and the trailer fell off the little wheel in the front and dropped on the tongue. Apparently the detent pin wasn't adequately set. Probably dropped about 12"-18". When I got off the boat, changed my drawers , I inspected the tongue and trailer and all appeared OK. I didn't see any cracked welds, crushed tubing, etc. The coupling mechanism on the extenstion (which is where the trailer hit the ground) looked OK and opened and closed as normal. I just chalked it up to $&!^ happens and when about closing up the boat for winter.
Frankly, it didn't occur to me until last night when I explained all this to the Admiral that there could be damage to the boat. Or at least, I started worrying about that possibility. What should I look for? Should I be calling the insurance company now? The boat was sitting on the keel over the axles and obviously, that didn't drop. The only area that dropped was the bow resting in the "V" at the front of the trailer and on the forward pads. Can I assume that the bow and hull in those areas can take such a load?
1999 C250 SR/WK #410
Bay Village, Ohio
Sailing Lake Erie
Don't Postpone Joy!
Response Posted - 10/11/2011 :  10:32:11  Show Profile
No Problem. Thick hull. Laid up well.
Response Posted - 10/11/2011 :  10:59:31  Show Profile
<br />. . . "V" at the front of the trailer and on the forward pads . . .
Rubber or carpeted "V" and carpeted forward pads - I bet the hull takes more pounding in rough waters.
Does the boat have a bow eye? Any signs of stress there?
Response Posted - 10/11/2011 :  11:12:40  Show Profile
You're right about the waves, OJ but they displace the force over a wider area. I guess my real concern is under the 12" square pads the the hull sits on. I doubt the bow eye hit anything since the bow is snug against the rubber "V". (Does that thing have a name?) But, I didn't look there and the boat's an hour away. I'll look Sunday when I go to cover her for the winter.
Ray, looking at all those lams is re-assuring.
Response Posted - 10/11/2011 :  12:09:36  Show Profile
<br /> . . . but they displace the force over a wider area . . . the rubber "V". (Does that thing have a name?) . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Excellent point John . . . V-block?
Response Posted - 10/11/2011 :  12:10:28  Show Profile
<br />...I doubt the bow eye hit anything since the bow is snug against the rubber "V". (Does that thing have a name?)<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yup--it's called "the V-shaped thing the bow presses against". Is your bow eye in contact with it? That would seem strange, but if so, just look for spider-cracks around the eye. Otherwise, the semi-vertical bow shouldn't be bothered by that "thing." Talk about a heavy layup--the bow typically has overlapping laminations from both sides of the hull. After all, it's built for newbies hitting docks.
Response Posted - 10/11/2011 :  13:49:58  Show Profile
It's called a "bow stop"
Response Posted - 10/11/2011 :  16:32:16  Show Profile
You might call your agent incase something comes up in the future. I would inspect internally an externally in the pad area, but wouldn't be to worried.
Response Posted - 10/11/2011 :  17:00:22  Show Profile  Visit delliottg's Homepage
John, glad you weren't hurt and hoping there's no damage to your boat. I think I'd call my insurance agent just so they're aware of the possible damage. While checking for obvious damage around where the v-thingy is, you should also look for remote damage that may have occurred. Since it was a shearing impact, there may be damage up around the deck joint or further back on the hull where you wouldn't expect.
I always called the thing up front the "snubber", but all the rest are just as good. Ours is a double on a see-saw type of pivot. I'll be damned if I can ever get the bow all the way snugged up to it. I used to try a good "high speed" stop to slide the boat forward, but it never worked, so I gave up.
We always put SL up on a cinder block so it's weight isn't sitting on the rolling jack.
Response Posted - 10/11/2011 :  17:33:03  Show Profile
The V-thingy prevents the eye from hitting the trailer support. I'll give Progressive a call tomorrow. I usually put some dunnage under the tongue and don't rely on the wheel but, that was a task I hadn't gotten to yet. I needed to scavenge the blocks from around the yard. They're there now.
Edited by - John Russell on 10/11/2011 17:34:28
Response Posted - 10/12/2011 :  05:42:26  Show Profile
Adjustable Jack stands...
Chris Z
Response Posted - 10/12/2011 :  06:42:15  Show Profile  Visit Chris Z's Homepage
I am not a big fan of the wheel type that swings up. I really couldn't see moving the trailer around with that front wheel on a C25. I put this one on my trailer and it can handle the load and there is no chance of it kicking out.
Response Posted - 10/12/2011 :  07:15:47  Show Profile
We use the same jack as Chris. Also mounted is a wheel which carries he weight of the trailer when strap-launching. I like this setup a lot although there are times when I wish I had the jack with the little wheel so I could give the trailer a shove when lining up to the hitch ball. When the trailer is in place we support the tongue with cinder blocks and raise the jack.
Response Posted - 10/12/2011 :  07:48:06  Show Profile
<br /> . . . I'll give Progressive a call tomorrow . . . <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Safe bet
