 remove rudder before ramp retrieval?
wegman
Initially Posted - 10/16/2011 :  13:37:46  Show Profile  Visit wegman's Homepage
I am about to ramp retrieve my new-to-me C25 89 wing keel for the first time. When the previous owner retrieved the boat, he removed the rudder while in the water, and then he pulled up the ramp. It would seem easier to remove the rudder later, after the boat is on the hard. But will an attached rudder scrape the ramp? The trailer is a DHL with rollers.
I could not find a post in the archive that addressed this point.
Thanks for the help.
Jerry
Jerry Wegman
C25 1989 SR/WK 5994
"Tenacity"
Response Posted - 10/16/2011 :  17:11:26  Show Profile
I can't envision a ramp that would cause it to scrape while retrieving/launching.
Of course at our marina, as soon as boat axles are on the level the tow vehicles starts up a hill which could cause the rudder to scrape the pavment.
I think you're okay at least until you get the trailer off/above the ramp. Certainly will be easier than installing/removing while on the water!
Response Posted - 10/16/2011 :  19:32:32  Show Profile
It's not particularly difficult to remove and replace the rudder afloat, some do it regularly to preserve the rudder. I have a kick-up rudder, and it has kicked up a couple of times over the years, but it is unusual to have happen.
Response Posted - 10/16/2011 :  19:45:26  Show Profile
Let's do the math... The WK draws 34". How much lower than the waterline is the bottom of your rudder? Subtract the two, and look at how much ground clearance the keel rest on the trailer has. If the clearance is greater than the difference, it seems to me you're good to pull.
sfsmith
Response Posted - 10/17/2011 :  07:55:44  Show Profile
Jerry, I have the same boat, and I have not had any problems leaving the rudder on. I think the ramp would have to have an unusual dip for the rudder to hit. In fact, I leave Tango's rudder on in storage. It's in a barn, and it only stays outside for a couple of hours after leaving the water.
wegman
Response Posted - 10/17/2011 :  09:46:10  Show Profile  Visit wegman's Homepage
Many thanks to all for your useful information.
Jerry
Response Posted - 10/17/2011 :  11:09:47  Show Profile
I gather you plan to remove the rudder for the winter, which is good. It's best not to let it freeze (in case there's moisture in the core).
Response Posted - 10/17/2011 :  19:38:23  Show Profile
Safest thing to do is pull the rudder, haul the boat out, then put the rudder back in place and see how much room you have. Each trailer will have a different set-up and clearance. As long as you have about 6" clearance, or more, you should be ok.
Edited by - dmpilc on 10/18/2011 19:51:37
Frank Law
Response Posted - 10/19/2011 :  13:44:03  Show Profile
Why take any chances !!! Take the rudder off it only take 3-5 minutes ,, I do it all the time..
Frank Law
About Time
1983 3519
SR SWK
C255885
Response Posted - 10/19/2011 :  17:36:34  Show Profile
I have a '89 25 that I dry slip. I only pulled the rudder to tow 500 miles. Never had a problem with scrapping when pulling out. Nor did the previous owner of almost 15 years.
Response Posted - 10/20/2011 :  05:30:41  Show Profile  Visit aeckhart's Homepage
My experience on the ramp that I use is that the rudder may make contact with the ramp where it meets the "ramp approach", depending on the angle of the ramp. At this point the rudder clears by an inch or less. Too close for my taste so I remove it once the boat is clear of the water but still on the ramp.
Response Posted - 10/20/2011 :  09:57:22  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by aeckhart</i>
<br />. . . where it meets the "ramp approach", depending on the angle of the ramp . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">That's the term I was looking for - or <i>approach to the ramp</i>
