 Cushion Damage
Initially Posted - 01/02/2012 :  11:00:42  Show Profile
As I mentioned in another post we had a water pipe rust through the other night and my boat cushions got wet.
I was only able to get the zippers to open on 3 of them and due to the construction of the cushions I was only able to completely remove one of the covers.
I put them out in the sun most of the day yesterday to dry them out and at the moment it doesn't appear that the fabric stained. When I brought them back in last night 2 or 3 of them were still damp in spots. They've been in the house all night and will remain in the house for at least a week so the AC/Heater can help suck out any remaining moisture.
My question is, what are the odds mold will start growing in the foam and is there anything I can treat the foam with now to prevent the growth of mold?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 01/02/2012 :  11:59:56  Show Profile
Turn a fan on them indoors, like a box fan, to speed up the drying, and as much direct sunlight outdoors as possible for several days.
Response Posted - 01/02/2012 :  12:14:53  Show Profile
I would say to totally dry them out. Any product with bleach will harm the foam so if you want to treat them with a spray mold killer/preventative that won't harm the foam or fabric and has no odor try a product like this.http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1& storeId=10051& catalogId=10053& productId=100654126& R=100654126
Response Posted - 01/02/2012 :  19:24:44  Show Profile
Great ideas guys. Didn't even think of the fan inside on the cushions even though I've had one going in the garage for two days.
Scott - Thanks for the info on the mold killer. I'll definitely get some of this stuff for the cushions.
I just finished tearing off the sheetrock and pulling down the insulation and it looks like the same mold killer will work for the walls even though at this time it doesn't look like I will need it (but I will use it anyway). Other than a few really wet areas the biggest part of the insulation stayed dry due to an underlayer of metalized fiberboard? that was under the sheetrock. I pulled it all down just to make sure.
Edited by - GaryB on 01/02/2012 19:26:45
Response Posted - 01/03/2012 :  08:55:50  Show Profile
If you can't get the zippers off the others, maybe try to oil the zipper-pull overnight and then use pliers to gently open the zipper.
My 33 year old metal zippers on the cushions are hard to work, but they still do move with some help.
Response Posted - 01/03/2012 :  14:31:54  Show Profile
Like John stated above, The zippers will benefit from a drop or two of WD40 or a penetrating oil left overnight then gently persuaded to move with the help of some needle nose pliers. I have done this on a few crusted up marine zippers through the years with about an 80% rate of success.
JeanAndre
Response Posted - 01/05/2012 :  18:51:50  Show Profile  Visit JeanAndre's Homepage
The oil on the zippers is a great idea to open them.
If your covers are in good shape, maybe replacing the zippers for Plastic zippers is a good idea...
If you don´t want to replace the whole zippers you can use cutting pliers to cut the rusted zipper car and replace just that.
Here in St. Louis we have had some very sunny days and it is suposed to stay lke this for a while, If you are having the same luck, give your cushions as much sun as you can.
In Brazil we say: The Sun is nature´s sanitizer.
just my 2/100...
Response Posted - 01/05/2012 :  20:03:45  Show Profile
The zippers are stuck because they wrapped the foam with some kind of fuzzy material and when they zipped them shut the fibers got tangled in the zippers.
I haven't messed with them much but think I can work them loose when I get some spare time.
Edited by - GaryB on 01/05/2012 20:04:31
