 Turning Ball Replacement
Turtle
Initially Posted - 01/06/2012 :  12:25:02  Show Profile
I've been following the forum for about a year now and learned alot in the process. However this is my first post. I haven't seen my question addressed and I don't find a direct response in the archives.
Question: How does one go about replacing the turning ball at the aft end of the centerboard trunk? Mine won't turn.
By way of background: My boat is 1995 WB. I've had it two seasons and sail it in the lakes of Oregon. The PO sailed it twice in Puget Sound for a week each time, but other than that it is fresh water boat.
The centerboard has always been difficult to raise. At the end of last season the steel cable failed near the connection to the head of the centerboard. I have lifted the boat from the trailer enough to get access to the top of the centerboard to cut and remove the remnant of the swage fitting and wire from the top of the centerboard. I took the opportunity to check the movement of the aft turning ball (not the block near the connection point to the centerboard) and find that it won't turn. Probably partly explains why the centerboard has been difficult to raise and perhaps contributed to the cable failure.
I see Catalina Direct has a replacement part which includes two turning blocks on a frame. Installing the part is supposed to make future replacement easier and, of course it should address my current problem. Anyone had luck with freeing and lubricating the turning ball? Anyone done the repalcement? CD also states that the turning balls should be replaced every couple years, though that strikes me as overly frequent, based in part on the lack of discussion about replacement in this forum. Thoughts?
Paloma
1995 WB Sail #143
Eugene, OR
zeil
Response Posted - 01/06/2012 :  15:07:55  Show Profile
Welcome to the forum Richard
Thank you for asking the question... look forward to suggestions from this esteemed forum.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I have lifted the boat from the trailer enough to get access to the top of the centerboard to cut and remove the remnant of the swage fitting and wire from the top of the centerboard. I took the opportunity to check the movement of the aft turning ball (not the block near the connection point to the centerboard) and find that it won't turn.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Would you mind posting a few photo's and description of the method of partly lifting the boat off the trailer to gain sufficient access to the aft section of the trunk...
Response Posted - 01/07/2012 :  14:52:04  Show Profile  Visit britinusa's Homepage
Good find Richard!
Here's the link to CD for the [url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=2360&ParentCat=232"]replacement kit.[/url]
And ditto Henk, pics of how you raised the boat on the trailer sufficient to get to the shackle on the centerboard.
Thanks.
zeil
Response Posted - 01/07/2012 :  16:57:34  Show Profile
Thank you Paul.. was not aware that a C-250 Centerboard Turning Ball Conversion Kit was available.
How does this need to be installed?
Must've missed the "boat from trailer raising", pictures... can you please resubmit them
Thanks in advance
Response Posted - 01/08/2012 :  08:44:12  Show Profile  Visit britinusa's Homepage
Henk, there's a link on that page to the drawings that explain how to do the mod.
I was agreeing with you, the pics of how to raise the boat on the trailer enough to gain access to the turning ball would be really valuable. I don't have any, but would like to see them.
zeil
Response Posted - 01/08/2012 :  10:06:01  Show Profile
Thanks Paul... Tried the "Read More... Centerboard Conversion Installation", but comes up blank
Yes... I would love to find out the best, or for that matter, any ideas to, safely, raise the boat sufficient from the trailer to allow center board work
Surely someone on this forum has experience, made photo's, outlined the procedure and/or archived the information somewhere
Edited by - zeil on 01/08/2012 10:13:08
Response Posted - 01/08/2012 :  15:13:16  Show Profile  Visit britinusa's Homepage
[url="http://www.catalinadirect.com/index.cfm?fuseaction=feature.display&feature_ID=145"]link to diagram[/url]
paul
zeil
Response Posted - 01/09/2012 :  12:03:57  Show Profile
Thanks Paul... had to re-install Adobe Reader before I could open it.
Response Posted - 01/11/2012 :  18:20:26  Show Profile
http://www.catalina-capri-25s.com/forum/topic.asp?ARCHIVE=true&TOPIC_ID=8756&SearchTerms=jack,bow#top
Here's a former post on raising the bow. My reply is the 9th one down. I used a rolling floor jack directly on the trailer with wood blocking under the bow.
