 Cockpit teak selection
Initially Posted - 03/19/2012 :  08:23:11  Show Profile  Visit Prospector's Homepage
Does anyone know whether Afrormosia ($6 per boardfoot) performs as well as "real" teak ($25 per board foot) under a coat of Cetol?
I have another supplier with better prices, but Noah's has a good writeup on each type of lumber:
http://www.noahsboatbuilding.com/items.asp?Cc=AFROMOSIA&iTpStatus=0&Tp=&Bc=
http://www.noahsboatbuilding.com/items.asp?Cc=Lumber%2DTeak&iTpStatus=0&Tp=&Bc=
I am making a mounting plate for some cockpit electronics and will need a fairly good sized hunk of whatever I decide to go with, but i fear that the afrormosia will be more prone to warping, checking, or some other unforeseen issues.
If the price difference is simply driven by demand, then I will be getting the cheaper wood for this, but if there are any quality issues folks are aware of, I'd really appreciate hearing from you.
"Iris"
1984 FK/SR #4040
Edited by - Prospector on 03/19/2012 08:31:00
JimGo
Response Posted - 03/19/2012 :  10:48:13  Show Profile
This is from [URL="http://www.higginshardwoods.com/products.php/specialtyhardwoods/afrormosia"]Higgins Hardwood[/URL]
Afrormosia closely resembles teak and is so often used as a teak substitute that it is sometimes referred to as African teak. It is prized for more than simply its resemblance to teak - it is also valued for character and properties all its own. It is grown in West Africa, primarily Ghana and the Ivory Coast.
Afrormosia is suitable for many applications, among them veneers, paneling, boat building, stairs, flooring, high-end joinery, cabinetmaking, farm implements, decks and marine piling.
Afrormosia is a heavy and dense wood that is extremely durable and very resistant to termites. This wood has a wide range of uses both for interior and exterior applications. It contains tannin, a substance that has a tendency to cause blue stains. If used near metals in wet conditions, such as in boatbuilding, it will cause corrosion or dark staining.
Sawdust from Afrormosia can be an eye irritant. Work this wood in conditions that provide good ventilation.
Afrormosia dries slowly with little degrade and small movement in service. The wood has medium resistance to tools. Experts recommend a 20 degree cutting angle to avoid raising the grain when planing. Tungsten carbide-tipped saws are recommended to avoid tool wear. Prebore for nailing and screwing. Afrormosia glues well and finishes excellently.
Wood is heavy and dense, has high bending strength, medium stiffness, high crushing strength, moderate bending classification. The wood may distort during steaming.
It is also listed [URL="http://albaraawood.com/download/woodrange.pdf"]in this PDF[/URL] as being used in marine decking and for other exterior marine purposes.
More information, this time from [url="http://www.connectedlines.com/wood/wood02.htm"]ConnectedLines.com[/URL]
Wood Properties of Afrormosia
Afrormosia Amount of Figure
Intermediate
Afrormosia Amount of Natural Luster
Medium
Afrormosia Availability of Wood
Limited
Afrormosia Available As Lumber
Yes
Afrormosia Available as Veneer
Yes
Afrormosia Available only in small sizes
No
Afrormosia Bending Strength
High
Afrormosia Blunting of Tool Blades
Moderate
Afrormosia Botanical Name
Pericopsis elata
Afrormosia Carving
Good, easy to carve
Afrormosia Clear Finish or Varnish
Insufficient Data Available
Afrormosia Color of Wood
Yellow or Golden Brown
Afrormosia Contrast between growth rings
Diffuse Porous
Afrormosia Crushing Strength
High
Afrormosia Decorative Figure
Yes
Afrormosia Density
High
Afrormosia Drilling
Good
Afrormosia Fill before Finishing
Afrormosia Gluing
Good
Afrormosia Grain
Mostly Straight
Afrormosia Growth Ring Pattern Plainsawn
Noticeable or Distinct growth ring
Afrormosia Growth Ring Pattern Quartersawn
Noticeable or distinct growth ring stripe, ribbon or flake pattern
Afrormosia Hand Tooling
Very Easy
Afrormosia Hardness
Hard, difficult to dent
Afrormosia Hardwood or Softwood
Hardwood
Afrormosia Harmful Properties
May cause dermatological and respiratory problems
Afrormosia Interlocked Grain
Yes
Afrormosia Kiln-dried Shrinkage
Low
Afrormosia Machine Tools
Easy to Very Easy
Afrormosia Mortising
Good
Afrormosia Movement after drying
Low
Afrormosia Nail Holding
Good- Nails are fairly difficult to pull out
Afrormosia Nailing
Tends to split wood - Requires pre-drilled pilot hole
Afrormosia Natural Durability
Very durable
Afrormosia Number of Knots
Afrormosia Painting
Afrormosia Planing
Fair
Afrormosia Polishing
Fair
Afrormosia Pounds per cubic foot maximum
44
Afrormosia Pounds per cubic foot minimum
44
Afrormosia Reacts with Iron Fasteners or Hardware
Yes
Afrormosia Sanding
Good
Afrormosia Sawing
Low cutting resistance
Afrormosia Screw Holding
Good - Fairly difficult to remove screws
Afrormosia Screwing
Tends to split wood - Requires pre-drilled pilot holes
Afrormosia Shaping
Good
Afrormosia Size of Knots
Afrormosia Size of Pores
Afrormosia Specific Gravity
Very high
Afrormosia Specific Gravity maximum
.69
Afrormosia Specific Gravity minimum
.69
Afrormosia Staining
Fair - May stain unevenly or change colors
Afrormosia Steam Bending
Satisfactory
Afrormosia Stiffness
Moderate
Afrormosia Surface Preparation for Finishing
No
Afrormosia Texture of the Wood
Moderately Fine
Afrormosia Toughness
Moderate
Afrormosia Turning
Good
Afrormosia Weight
Heavy
Afrormosia Wood Defects
Few drying defects
Afrormosia Work Notes
Hard mineral deposits require sharp or carbide tipped saw knives
Afrormosia Use for Boxes, Crates or Pallets
no
Afrormosia Use for Carving
no
Afrormosia Use for Cooperage
no
Afrormosia Use for Decorative Veneer
YES
Afrormosia Use for Flooring
YES
Afrormosia Use for Furniture
YES
Afrormosia Use for Handles
no
Afrormosia Use for Heavy Construction
no
Afrormosia Use for Inlay
no
Afrormosia Use for Interior Finish
YES
Afrormosia Use for Light Construction
no
Afrormosia Use for Marine Applications
YES
Afrormosia Use for Marquetry
no
Afrormosia Use for Millwork
YES
Afrormosia Use for Models and Patterns
no
Afrormosia Use for Musical Instruments
no
Afrormosia Use for Novelties
no
Afrormosia Use for Secondary Furniture Components
no
Afrormosia Use for Shingles
no
Afrormosia Use for Sports Equipment
no
Afrormosia Use for Turnery
no
Afrormosia Use for Woodenware
no
Happy D
Response Posted - 03/19/2012 :  16:46:07  Show Profile
What does "a fairly good sized hunk of wood" mean? I might be able to help out.
Response Posted - 03/19/2012 :  16:48:41  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Happy D</i>
<br />What does "a fairly good sized hunk of wood" mean? I might be able to help out.
I could use a 12x14x1/2 chunk of teak.
Response Posted - 03/19/2012 :  16:56:46  Show Profile
For that size I'd go with teak.
You may also want to try mahogany - I've used it in the cockpit and under a few coats of honey-colored Cetol I'd challenge most people to tell me which is which.
Response Posted - 03/19/2012 :  18:56:14  Show Profile
I like working with mahogany. When I was a kid, my dad restored an old Yellow Jacket boat...it had a mahogany dashboard buried under many layers of paint. He stripped it down and rescued that dash. With brass trimmed instruments, it was absolutely gorgeous.
Response Posted - 03/19/2012 :  20:25:24  Show Profile  Visit Prospector's Homepage
I'm looking at about the same size as joe - need to do a gauge delete, so I'm thinking backing plates for gauges on both sides of the companionway for symmetry.
JimGo
Response Posted - 03/20/2012 :  05:54:08  Show Profile
Is 12x14 your actual, finished size, or just what you need to be able to cut out the pieces? The reason I ask is that you can frequently find teak furniture on Craigslist, or even Freecycle, for very reasonable prices. You might be able to take the pieces from the furniture and glue them up to get the parts you need.
Response Posted - 03/20/2012 :  06:30:42  Show Profile  Visit Prospector's Homepage
I've been watching there too Jim - just be careful that what you are buying really is teak, and not teak veneer over particle board.
Response Posted - 03/20/2012 :  06:36:35  Show Profile
I'm also doing a guage delete. I have 2 big 4" holes on top of each other I need to cover. The 12x14 is a rough size but accurate within an inch or two of the finished size.
Happy D
Response Posted - 03/20/2012 :  16:08:14  Show Profile
I think if I had two large holes to fill I would be inclined to fill them with core wood, fiberglass and top it off with gelcoat so it looked like it never had holes. It's a lot of work but then you're starting with a clean slate.
The biggest problem is the inside gelcoat is finished in texture and will be impossible to match nicely.
Response Posted - 03/20/2012 :  17:11:28  Show Profile
<br />The biggest problem is the inside gelcoat is finished in texture and will be impossible to match nicely.
Damn....make that 2 pieces of teak......
Sam001
Vice Commodore
Response Posted - 03/20/2012 :  18:21:22  Show Profile
remember teak is teak
we love it we hate it but it is still teak
and just about last for - ever!
Response Posted - 03/21/2012 :  06:29:44  Show Profile
Yes, teak is a wonderful wood.....but mahogany is also stunning when worked. It has a beautiful grain and is so warm and soft when varnished. Doesn't have the staying power of teak for the outside stuff though, but inside can be stunning.
Sam001
Vice Commodore
Response Posted - 03/21/2012 :  07:04:29  Show Profile
I agree I made a coffee table out of a "slab" of mahogany and it is beautiful.
It took a while to sand it down to the surface I wanted.
