I've done a few metal shaping projects and for this I might try putting the work in a vice then pounding it into shape. So as to not mar the work, I hold a small piece of wood over the area to be shaped when hammering. Since you need to match the boom curve, maybe you could replicate the curve using a piece of wood then clamp it and the sheave box in a vice together then hammer the flange into shape.
I would clamp one flange in a vise and put a crescent wrench around the pulley/holder and bend it to the angle needed. Then repeat it for the other side.
I would go with a pad on the internal boom surface with a glob of epoxy putty. Press it firmly in place to eliminate voids and flatten the surface with a piece of wet plastic before it sets.
OJ, I am a little fuzzy here - you are putting the flanges inside the boom with just the lip of the sheave exposed, right?
So you need the flanges bent back to fit the inside contour of the boom? Basically like this will be an exit block for te outhaul at the back of the boom?
This is more challenging than it first appears. Bending the flanges without mishaping the box! As thin as the ss sheet metal appears - it's very rigid.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Prospector</i> <br />OJ, I am a little fuzzy here - you are putting the flanges inside the boom with just the lip of the sheave exposed, right?
So you need the flanges bent back to fit the inside contour of the boom? Basically like this will be an exit block for te outhaul at the back of the boom? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Interesting thought Chris. Flanges will sit on top of boom. Stainless wire will connect to clew, run through box and connect to fiddle blocks inside boom. Line from fiddle blocks will exit boom near gooseneck, down mast and back to cockpit.
OH - now I get it. I still think it would look cleaner inside the boom with just a couple rivets or screws sticking out. The nice thing on our booms is that you can remove the end plate to do this stuff.
Stainless does have great "memory" and it does not work easily. When I was doing metal spinning for a living, deforming stainless (any type/grade) was a fine balance between having a part explode and getting the right contours. Heating it only makes it more brittle, don't do that. I would be very tempted to bend it in 1/8" steps until you get a curve you can live with.
OJ, According to the web page you provided: "The external tabs can be formed to fit the spar profile before fastening." If bending the tabs ruins it I would return it and quote what the web page says.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Sloop Smitten</i> <br />If bending the tabs ruins it I would return it and quote what the web page says.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Joe! Funny!
Yes, the people at Ronstan in Portsmith, RI had zero advice about this task - borderline apathetic .
A friend a has large vice and (as suggested above) will place round bar stock under the flange and strike it with a hammer (with a piece of oak in between.)
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i> <br />How are you going to get it in place?
Paul <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Hi Paul! Will drill a small series of holes in the bolt rope slot just in front of the aft boom cap casting . . . then square up with a file.
Results - as suggested above - placed sheave box in a vice with a rod under the flange. Used brass bar stock (brass being soft) and hammer to round the flanges.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PCP777</i> <br />Looks awesome, I have an internal out haul ran to the cabin top, let me see how it was done. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Peter, I have a question for you first! Any pix of where your internal outhaul exits the forward part of the boom? I have an exit block for the line - I'm just not sure about placement . . .
