 Best product to clean the boot stripe
BCG-Woodbury
Mainsheet Editor
Initially Posted - 07/02/2012 :  16:44:24  Show Profile
My boot stripe has some staining at the waterline. Does anyone have a really good product to clean it. It is a little faded too but I think I can renew that with a little compound when I shine up the sides. Any input is appreciated.
Brian & JoAnne Gleissner
Knot So Fast
1984 Catalina 25, SR/SK
Traditional Interior
Lake Candlewood, CT
Response Posted - 07/02/2012 :  16:49:34  Show Profile  Visit delliottg's Homepage
[url="http://www.westmarine.com/buy/products/2100-fsr-fiberglass-stain-remover.html#.T_IzWkheuRs"]FSR[/url] will probably do it for you, but you can also use ketchup, or so I've read. It's the acid that bleaches out the stain.
putzmeister
Response Posted - 07/02/2012 :  17:05:42  Show Profile
Also available at WM. This product will eat the copper in your bottom paint - read the label.
http://www.jamestowndistributors.com/userportal/show_product.do?pid=2339
Response Posted - 07/02/2012 :  17:11:54  Show Profile
[url="http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=109319&catalogId=10001&langId=-1&storeId=11151&storeNum=50218&subdeptNum=50268&classNum=50270#.T_I4F7_Tq3c"]Starbrite Instant Hull Cleaner[/url]
Everything this company makes - works.
BCG-Woodbury
Mainsheet Editor
Response Posted - 07/02/2012 :  17:31:17  Show Profile
Thanks all, I'll check these products out tomorrow locally.
Best regards,
Response Posted - 07/02/2012 :  18:24:22  Show Profile
I use toilet bowl cleaner to easily remove the scum line.
dragonf1y
Response Posted - 07/02/2012 :  18:36:04  Show Profile
Do these products remove scuff marks? I have a few black marks on my starboard bow from a state park mooring buoy (tire).
Response Posted - 07/02/2012 :  19:57:07  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dragonf1y</i>
<br />Do these products remove scuff marks? I have a few black marks on my starboard bow from a state park mooring buoy (tire).
This is great for scuff marks.
[url="http://www.mrclean.com/en_US/magic-eraser.do"]Mr Clean Magic Eraser[/url]
Response Posted - 07/02/2012 :  20:06:26  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">This is great for scuff marks.
And almost everything else
Response Posted - 07/02/2012 :  20:10:28  Show Profile  Visit delliottg's Homepage
You'll probably need to apply a scrubby & elbow grease to get those off. Some Scrub Brite will help with the mild abrasive that's built in. Just don't get it on your clothes.
Response Posted - 07/02/2012 :  21:20:02  Show Profile
Sometimes the Gel Coat gets oxidized and becomes cloudy - that can make your bootstripe appear faded as well. If it looks whitish and patchy, it could be oxidized. WM also sells a treatment for that.
Response Posted - 07/03/2012 :  05:55:59  Show Profile
I've found Black Streak Remover (RV/Boat section at Walmart) removes not only black streaks, but scuff marks, bird and spider crap stains, tree sap, and a host of other stains. It's my universal cleaner.
NautiC25
Response Posted - 07/03/2012 :  06:53:21  Show Profile
Does Acetone work on scuffs? I plan to use it tomorrow on the rudder where I accidently got some VC-17 above the paint line. It's safe to use on plastics and removed the black writing off a pvc tube very easily.
Edited by - NautiC25 on 07/03/2012 06:57:56
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 07/03/2012 :  11:05:23  Show Profile
I just picked up some Turtle Wax polishing compound, rubbing compound, and hard shell wax (and an orbital buffer) to try to restore the shine on the gel coat on my topsides, boot stripe, and cove stripe, all of which are severely oxidized. Does anybody have any experience with or thoughts on those products?
Response Posted - 07/03/2012 :  13:57:00  Show Profile
Seth, Turtle Wax's Carnauba Cleaner Wax ( There is a difference from regular Turtle wax) is my favorite. The only wax that I have found that puts the deep color back in the boot stripe and keeps it that way for almost the full season for me and doesn't cost but $6-7. Does a great job on the hull also with the buffer. I don't use an orbital buffer but instead I use a variable speed buffer/sander.
If its severely oxidized like my deck and cabin top was It would be an easier job to cut through the heavy stuff by wet sanding with a 3M scrubby (The least abrasive one's you can find) and a water hose running on the scrubby as you gently scrub the heavy stuff off then you can buff it to a nice shine with just the cleaner wax.
Edited by - islander on 07/03/2012 14:27:21
BCG-Woodbury
Mainsheet Editor
Response Posted - 07/03/2012 :  16:19:43  Show Profile
I went to Home Depot on my way to the boat today. I looked in the Cleaner section and they had a ZEP Commercial Grade, Acidic Toilet Bowl Cleaner. I figured I couldn't go wrong and could probably return it if it didn't work. I applied some to a rag and proceeded to rub it on the stain and slime residue. It was like magic, removed all the staining and slime residue easily. A good solution for $5 but make sure you wear gloves and safety glasses. The label says "Acidic" but doesn't say what kind. Emergency care say flush woth water, which is typical of most acids.
sethp001
Response Posted - 07/03/2012 :  19:08:10  Show Profile
I was doing some testing/experimenting while doing my bottom job. I noticed that sanding the severely oxidized boot stripe with a rotary sander pad on my cordless drill and a 320 grit sandpaper also seemed to nicely remove the oxidation without appearing to hurt the paint. I sanded about a one foot section quickly with good results, but intend to see how the rubbing compound does first before doing any more with the sandpaper.
I have a grinder too. Do you think the grinder (with proper attachment) would be better or easier than an orbital buffer?
putzmeister
Response Posted - 07/04/2012 :  06:39:04  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sethp001</i>
<br />. . . sanding the severely oxidized boot stripe with a rotary sander pad on my cordless drill and a 320 grit sandpaper also seemed to nicely remove the oxidation without appearing to hurt the paint . . . I have a grinder too. Do you think the grinder (with proper attachment) would be better or easier than an orbital buffer?
320 is way too coarse - you are greatly shortening the life of the gel coat. The RPMs of a grinder are too high and will generate too much heat = burning the gel coat.
This is from a pro:
http://www.sailnet.com/forums/gear-maintenance/52772-tips-compound-polish-wax.html
Stu Jackson C34
Response Posted - 07/04/2012 :  09:29:05  Show Profile
On & Off should be banned from use the same as 5200, Satan's Glue!!!
O&O is dangerous stuff. I far prefer FSR for brown hull stains. Much less toxic. We have an extendable pole (bought at ACE Hardware for $12!!!) and one of the automotive windshield squeegees with the wiper on one side and the sponge on the other side, with the red handles. Unscrew the handle, screw into extendable pole, pour some FSR on the sponge side and apply to the hull. O&O is more liquid than the gel FSR and is, did I mention, way too toxic for me.
Acetone works great on black streaks.
Paint brush cleaner is far superior for cleaning white fenders than acetone.
Edited by - Stu Jackson C34 on 07/04/2012 09:31:54
Response Posted - 07/05/2012 :  05:51:43  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by BCG-Woodbury</i>
<br />I went to Home Depot on my way to the boat today. I looked in the Cleaner section and they had a ZEP Commercial Grade, Acidic Toilet Bowl Cleaner...I applied some to a rag and proceeded to rub it on the stain and slime residue. It was like magic, removed all the staining and slime residue easily.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Yep, like magic. At the end of the season when the boat is on the hard, I'll paint the toilet bowl cleaner gel on the scumline, wait a few minutes to let it do its work while sometimes using a scrubby pad on the thick stuff, then watch the stains disappear.
sethp001
Response Posted - 07/06/2012 :  06:48:06  Show Profile
I notice the Turtle wax can says "not for vinyl paints". I think the stripes are vinyl, right? I wonder what happens if you put in on vinyl paint.
BCG-Woodbury
Mainsheet Editor
Response Posted - 07/06/2012 :  09:37:14  Show Profile
Hi Seth -
The boot stripe is right in the gelcoat on my 1984. Compounds and Waxes should be fine on it. Maybe the newer boats have a vinyl tape boot stripe.
Regards,
NCBrew
Response Posted - 07/06/2012 :  14:38:01  Show Profile
Try "barkeepers friend" near the cleansers in the grocery store. Just put it on with a wet cloth. Do not rub. Let it sit and wipe it off. Works great on the Intercoastal brown tanic stain,
