 gas tank locker seat support
Deborah
Initially Posted - 07/08/2012 :  09:30:55  Show Profile
is their a support available for gas tank locker seat?
1985 Catalina 25 Fin Keel #5160
"Mottley Crew"
Spring Grove, IL
blanik
Response Posted - 07/08/2012 :  10:40:29  Show Profile
define support?
Response Posted - 07/08/2012 :  11:55:42  Show Profile
If you mean to hold it up, no. I could secure mine in the up position with my adjustable backstay line or a bungee.
Response Posted - 07/08/2012 :  13:48:00  Show Profile
A bungee worked for me. Unfortunately I didn't use one on the "dumpster" lid when I climbed inside and slid on my back to the transom... A puff blew the lid closed--total darkness.
Response Posted - 07/08/2012 :  14:34:27  Show Profile
If you mean support as in the bottom slides off the lip,No, you will have to make somthing to prevent that like I did but if you mean as in something to hold it open, No again but I can wedge mine open against the back stay.
Response Posted - 07/08/2012 :  18:10:17  Show Profile
Does the seat flex-like has it been cracked or weakened? Or does it just slip off the lip like in Scott's "Islander's" case? I've tightened the hinge bolts/screws and that seems to help.
