 How To Turn Lg. Engine W/out Soft Link?
jfesi
Initially Posted - 01/15/2003 :  11:29:28  Show Profile
I'm sure this question has been asked and addressed but I'll ask it one more time for perhaps new ideas or member input. Here gos...
I have a 2002 wb250 and the dealer sold me a high thrust, 4 stroke Yamaha 9.9 long shaft. Love the engine when away from docking area (great power and speed)but with the small engine slot design of the catalina 250, the engine must be locked in place making docking in tight quarters tricky to say the least. Now that my slip has been relocated I'm really dealing with a difficult situation. I've always admired Arlyns soft link, but the 9.9 is just to large. Does anyone have a possible solution? I was told by a non 250 sailer to put a rear mounted outer bracket on to push the engine out away from the rear end thus allow for turn room, but I think that extended outward weight could become an issue. ANY SUGGESTIONS??? Thanks.
Tropical Sleigh wb250 Sarasota FL
jguyot
Response Posted - 01/15/2003 :  15:09:42  Show Profile
Hi Rochester
If you haven't already, go to the top of the screen & use the search function and look up "outboard bracket" in the 250 Forum. It should bring up 4-5 threads on this subject. I have a 2001 250WK with a Honda 8hp XLS and had ordered the fixed mount outboard bracket when I ordered the boat. In one of those threads, I posted a picture of it. It works great. I will look & see if I have any other pictures of it and will post them when I find them.
Jerry Guyot
250WK #586
"Sail La Vie"
jguyot
Response Posted - 01/15/2003 :  15:59:26  Show Profile
Hi Rochester
Here is a picture of the bracket
<img src="http://im1.shutterfly.com/procserv/47b3df34b3127cce9396a3b069a00000001410" border=0>
Another View
<img src="http://im1.shutterfly.com/procserv/47b3df34b3127cce9396a3b269a20000001410" border=0>
Hope this helps....
Jerry Guyot
250WK #586
"Sail La Vie"
jfesi
Response Posted - 01/15/2003 :  17:42:21  Show Profile
Hey Jerry, for some odd reason I can't seem to open your pictures in this thread or in past threads. I sent you an email. Reading past threads makes me wonder if I'm the only 250 owner who bought a yamaha 9.9. That outboard bracket is an interesting idea, but I wonder if there will be enough room still for that darn motor tiller handle.
Tropical Sleigh WB619
Sarasota FL
lhooks
Response Posted - 01/16/2003 :  22:39:42  Show Profile
Since I still waiting on delivery of my 250, I need to know:
Do I need the outboard bracket?
I am getting a Honda 8.
One dealer told me I needed it but my dealer said I didn't but I know he is new and not as knowledgeable as others.
Does the bracket keep the tiller from hitting the blade?
Would the Soft-Link (or a hard one) do the same?
Leonard Hooks 250WK
Waco, TX
Response Posted - 01/16/2003 :  22:56:16  Show Profile
The Honda will yield a full port turn but only about half the starboard turn as the motor tiller contacts the fuel locker. I don't find it much problem.
And, the soft link will still work as the starboard turn uses the bungee for that turn so not stopping the rudder.
Arlyn C-250 W/B #224
R&R N/E Texas and Great Lakes
bren737
Response Posted - 01/16/2003 :  23:48:39  Show Profile
Hi guys,
I've got a 2002 WB and this has been the only compaint I've had with the boat. I've got an '02 Honda 9.9 and it's just too damn big for the limited space between the fuel locker and the gunwhale.
I've not yet found it enough of a problem to warrant adding the "outboard" outboard bracket. I'd be concerned about the flex of the the transom with that heavy motor hanging out and away from it when trailering and I don't want to unship the motor each time I trailer the boat.
My solution thus far is to plan ahead in my marina maneuvering by keeping in reserve my ability to swing the motor to port only ( as Arlyn pointed out). In other words, three left turns make a right turn! <img src=icon_smile_wink.gif border=0 align=middle> Not real seamanlike (I know I've caught you laughing at me, Derek!) but it works. It's not really a factor unless the wind is blowing from the wrong direction.
Bren Peterson
C250WB, #642, "Ruah"
San Antonio, TX
jfesi
Response Posted - 01/17/2003 :  00:15:12  Show Profile
I've been mulling over this whole limited space thing, and I thought of a possible solution (aside from the bracket). As I've stated in the past I have a 9.9 Yamaha. If the engine didn't have that control tiller resting along side the fuel locker a starboard turn would be easier to achieve(port is good now). With this burning thought I called a local Yamaha dealer and was informed it's possible to remove the arm and then connect a control box for the controls in a choice location. This would provide about another inch and a half of space, making a starboard turn easier to achieve. Anyone ever hear of such a plan?
Tropical Sleigh wb619
bear
Response Posted - 01/17/2003 :  10:24:39  Show Profile
Hi Guys,
My slip on The Great Sacandaga Lake faces out on the lake,
not to well protected from northerly winds. I have the 8 H.P.
Honda four stroke with a bracket that sticks out about ten inches.
What I have found is backing the boat into the slip useing the motor and tiller together [no soft link]. This does work well and when single handed sailing lets me grab the dock with the boat hook from the cockpit. Doing this also eliminates the wave "slap" at the back of the boat when docked with the stern faceing out. Anybody else tried this? "Bear" on C250 WB "Really on the hard" in upstate N.Y.
jguyot
Response Posted - 01/17/2003 :  11:31:45  Show Profile
Hi Leonard
I also have the Honda 8 and the bracket as you can see above. The bracket does move the engine back far enough so that the blade will not hit the rudder.
I have trailed the boat over 200 miles with the motor attached and have not had any problems with the mount.
Rochester - As you can see, I do not have a tiller arm on my motor (All controls are on the pedestal). The only problem I have, and it is minor, in turning the motor, is that the "Shift Cables" are a little stiff and that makes it a "little bit" harder to turn the motor manually. But having all the controls at the pedestal far outweighs that minor problem!
Just checking, is anyone else having a problem not seeing the pictures above? I just want to make sure I did it right ! <img src=icon_smile.gif border=0 align=middle>
Jerry Guyot
250WK #586
"Sail La Vie"
Response Posted - 01/17/2003 :  11:51:02  Show Profile
Bren, I can move mine to starboard also, but only about 20 degrees and then the casting for the tiller arm hits the fuel locker. To accomplish the 20 degrees, the motor has to be shifted fully towards starboard which may require an addition to the backing plate.
If I had guts...I would hack saw off part of the casting to the tiller arm...<img src=icon_smile_sad.gif border=0 align=middle>
andy
Response Posted - 01/21/2003 :  19:42:17  Show Profile  Visit andy's Homepage
Guys...my aux is a '98 evinrude 4cycle 8hp and it's wide (however I don't know how it compares to the honda). I don't think the soft link would work for me because of the width. I also have a fairly tight slip. I offset the engine slightly to starboard and that seems to give enough turn although not full capacity for the motor. I haven't found it a problem. The boat manuvers nicely on the rudder alone...if I need to manuver tightly, I use a combination of motor turn, forward-reverse and the rudder. I dont like the idea of hanging the motor way off the stern. Hey.. inboards (not saildrives) gotta manuver on the rudder alone... we're all spoiled!
Andy Anderson
C250WB #163
MHYC McCall Idaho
jkey6
Response Posted - 01/30/2003 :  22:53:29  Show Profile
Arlyn,
Get out your hacksaw or better yet your side grinder. When I added your softlink to my C250 WK, I was disappointed in the turn range of my Nissan 9.9 hp. My boat did not have a 'power wand' because I had Pedestal mounted controls but the motor did have brackets that interferred with steering.
I took the motor off and used a side grinder to cut off all protruding interferences. The side grinder easily cut the aluminum brackets and it was easy to smooth the cuts by rounding over the cut areas. These parts of my motor were aluminum and I do not believe anyone would ever notice that I had cut the pieces off.
It was an easy job that took less than 15 minutes and made my Nissan 9.9 able to rotate more than I would ever need. Prior to cutting, my starboard turn was limited to maybe 20 degrees (maybe 10) it is now at least 45.
Thanks again for your softlink idea. Made my boat what I wanted. Cut off anything that is not needed but limits the range of motion of your ouboard.
JKEY on
"All Keyed Up" #447 C250 WK.
Tony
Response Posted - 01/31/2003 :  15:36:01  Show Profile
Hi. I'm in the process of converting a 9.9 hp evenrude to pedestal control. The long awaited backordered kit I need is winging its way to my dealer as we speak, after a short 6 month wait. My question to those of you with pedestal controls, where do the cables enter the boat and what was used to make the entrance water tight(resistent?).A picture or drawing or better yet , aplace to purchase the part would really help. Thanks, Tony
Bryan Beamer
Response Posted - 01/31/2003 :  23:56:21  Show Profile
HiTony,
This is not a good picture of the rubber inlet. It will give you an idea of where it enters the boat.
The black thing at the bottom of the picture is the inlet. You can see the black battery cord and the 2 red motor control cables going into it.
<img src="http://im1.shutterfly.com/procserv/47b3df05b3127cce93a98040c8b30000004610" border=0>
If someone dosen't have a better picture of this I will take a few tomorrow while I'm at the boat and post them on Sunday.
As for where to buy the rubber inlet, I'm not sure. West Marine should carry it.
I thought the c250 came from the factory with the inlet already installed. If you have pedistal controls or not, the cable that connects to the battery still goes in the same place.
Bryan Beamer
Daylight Again
C250wk #495
Edited by - Bryan Beamer on 02/01/2003 00:16:59
jkey6
Response Posted - 02/02/2003 :  17:13:02  Show Profile
I expect that dealers route the pedastal controls after the boat is delivered.
My Year 2000 C250WK has pedestal controls. The cables arc around the front of the motor and enter the boat through an acordian like rubber grommet on the transom. Works fine, I think I like the way Bryan's installation looks better.
JKEY
'All Keyed Up' C250WK #447.
Bryan Beamer
Response Posted - 02/02/2003 :  17:14:39  Show Profile
Tony
Here are a couple more pictures of the inlet for the motor controls.
<img src="http://im1.shutterfly.com/procserv/47b3dc23b3127cce9462dfca4eda0000001610" border=0>
<img src="http://im1.shutterfly.com/procserv/47b3dc23b3127cce9462de000e880000001610" border=0>
Bryan Beamer
Daylight Again
C250wk #495
Edited by - Bryan Beamer on 02/02/2003 17:19:40
jkey6
Response Posted - 02/02/2003 :  17:14:44  Show Profile
Bryan,
Nice solar charger mount - it looks exactly like I mounted mine. Only place on the boat that interferes with nothing.
JKEY
jkey6
Response Posted - 02/02/2003 :  17:18:49  Show Profile
Looking at the detailed photo, I think I like my dealers solution better after all. My cables turn a tight radius around the front of the motor then curve again to enter the boat through the transom.
I think that when I stand to rotate my motor, my feet are where the cables are in the photo.
JKEY
Tony
Response Posted - 02/02/2003 :  21:56:01  Show Profile
Bryan, Thank's for the great photo's. I really appreciate the help. This association is easily the best $20.00 I spend each year. Tony
