 Stayed dry
hewebb
Initially Posted - 08/27/2012 :  03:25:36  Show Profile
Last week I brought the boat home to do some work on it. One of the items was replacing the plastic in the forward hatch. (Old one cracked) Yesterday it rained hard for a long time and I was able to check for leaks. I got lucky because the rain stayed outside and I found no water intrusion. Checked the entire boat with good results.
Hobie 18 Lake Worth
Response Posted - 08/27/2012 :  14:13:22  Show Profile
Nice to hear the words "it rained hard for a long time" in TX as it has been drought conditions there, no? Glad to hear your fix "took".
Response Posted - 08/27/2012 :  19:10:14  Show Profile  Visit Prospector's Homepage
You got lucky in the Vee berth? Any other details?
hewebb
Response Posted - 08/28/2012 :  03:53:59  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
You got lucky in the Vee berth? Any other details?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I purchased the lexan from the local plastics supply house. I removed the frame and old plastic and used the old plastic for a pattern to cut and drill the new one. After cleaning up the frame and gaskets (acetone) I used epoxy to glue the gasket to the frame. I held the gasket in place with masking tape until cured-24 hours. I placed the lexan in with small spacers to center it in the frame then clamp in place and remove the blocks. I used Black automotive silicone adhesive to glue it in. I used masking tape to cover the lexan and alum frame for a clean edge. The plastic parts of the alum latch that went through the plastic were in nearly un-usable condition so I machined some new ones from alum. The alum pieces are installed with thin Teflon washers and a rubber seal I duplicated the installation with a test piece and it is setting outside as a test to see how it holds up. Previous to this I had removed the entire hatch and resealed to the deck.
Response Posted - 08/28/2012 :  06:28:39  Show Profile
My v-berth hatch is about the only thing that doesn't leak on my boat.....
hewebb
Response Posted - 08/29/2012 :  04:20:43  Show Profile
Scott
I have been chasing a couple of leaks since I got the boat-I think I finally have them fixed. The other one that took some time to find was the pop-top to cabin on the starboard side. I think the companion way would leak in the wind/rain from aft.
Response Posted - 08/29/2012 :  07:41:51  Show Profile
Yeah, I get alot of that......
