 Anyone disassembled their whisker pole?
NautiC25
Initially Posted - 10/23/2012 :  07:33:18  Show Profile
I have the 7-17 twist lock and one of the cams aren't locking. I'd like to try and take it apart to clean it up. Are the ends glued together or something? If I remove them, will I have problems putting them back on?
1989 C-25 TR/WK #5894
Miss Behavin'
Sittin' in LCYC on Canyon Lake, Texas
PZell
Response Posted - 10/23/2012 :  09:59:01  Show Profile
I'll be watching for answers. I have 7-17 whisker pole sitting in my shed missing the smallest extension. It was lost on a particularly blustery day while trying to do a take down as rounding a mark. Long story short it pulled out and eventually came off the sheet. So you can probably just pull the extensions apart. I keep meaning to get a replacement section but have been doing fine with the 15 foot one Forespar makes now. You should just email Forespar your question. They are good on replying.
Edited by - PZell on 10/23/2012 10:01:57
Response Posted - 10/23/2012 :  10:08:29  Show Profile
Jonathan, the sections pull apart with a little persuasion. Forespar sells a replacement kit for the locking clutches but it's a bit tricky to install.
NautiC25
Response Posted - 10/23/2012 :  12:10:26  Show Profile
Wow, it must take a LOT of persuasion. I spent last night trying to pull it apart and then was worried because I had a hard time getting it to compress back again. lol I didn't know how it came apart and didn't want to break anything. I'll try pulling a little harder. Thanks!
I saw the kit for $33 at WM. If I can't fix what I have, then I'll purchase the kit.
Edited by - NautiC25 on 10/23/2012 12:12:40
NautiC25
Response Posted - 10/23/2012 :  19:07:50  Show Profile
Woohoo! So I gave the faulty section a good yank to free the end where the cam is located. My guess was that the cam was "rounded out" from age. So, I took a piece of thick wire, shoved it behind the cam's big side to thicken it up, then put it back together. It's now just tight enough to keep the pole from compressing. Saved $40. :)
Edited by - NautiC25 on 10/23/2012 19:08:18
rrick
Response Posted - 10/31/2012 :  01:42:43  Show Profile
My pole is about 3" shorter after I squared up the fitting ends with a chop saw. Fresh rivet holes could then be drilled eliminating wobbling ends. This is where you started, right?
Grind off the rivets, remove the fittings, and slide the sections apart. For visualization and project planning for those doing this job, the cam is a two piece plastic part with one half fitting the inside circumference of the pole and the other half is the cam (a rubber ring is stretched over the cam for grip). The non-cam side is held to the aluminum pole with four awl punches. After 30 years of twist lock actions (or perhaps a few gorilla strength twists) the non-cam side plastic was no longer fitted to the punches. I was almost certain I'd crack the aged plastic with four hammer blows, but had no problem. It was nice to clean up the rubber cam and pole interior of powdery aluminum oxide. Some old blue tape fell out off the poles in this process, I later found this to be a part of the $40 rebuild kit (index mark to prevent hyperextension?).
For some folks, you aren't just saving $40 on a rebuild kit, but eliminating the neurotic temptation to apply that $40 towards an upgrade to the latest-greatest downwind device. Spending under a buck on a rebuild is easily satisfying to everyone. Parts list is rivets. Minimum tool list is twist drill to remove old rivets, hammer and punching awl, and rivet tool.
Edited by - rrick on 10/31/2012 01:44:26
