 New boat - some questions
Arlington
Response Posted - 01/08/2013 :  09:54:13  Show Profile
Hi Steve:
Mine is tucked inside of the port coaming in the cockpit. Here is a link to photos taken by the PO.
http://picasaweb.google.com/BabuHu/Babu_C25?authkey=Gv1sRgCOGHv_Sy-O2VTA&feat=directlink
It is the 20th photo in the album. The boat came with a 25 ft long shore power cord, and I bought another 50 ft of standard wiring and connectors on Ebay and made an longer cord. It was about half the price of buying a shore power cord that was already assembled.
Doug
Response Posted - 01/08/2013 :  18:48:37  Show Profile
Mine is in the port coaming like the Arlington's.
Response Posted - 01/09/2013 :  17:33:50  Show Profile
Just make sure you look behind the coaming to make sure there is nothing that could be damaged when you drill through with a hole saw.
Be careful where you mount it in relation to the vertical axis. I have to work to get my cable plugged in because the cord hits the lower edge of the coaming box. The cable ends up with a sharp bend in it where it crosses over the edge of the box. If it were mounted slightly higher it would plug straight in without having to bend it.
