 Nice table work
Initially Posted - 03/06/2013 :  04:54:54  Show Profile  Visit britinusa's Homepage
I was browsing through the Photo Gallery and found this Album showing the mod to the [url="https://www.catalina-capri-25s.net/cgi-local/MBR_gallery.cgi?Album+2166+93"]C25 Table[/url]. I must admit, it's a really nice table that could not be done in a C250.
Still looking at modifying my modified table on JD, far too much hassle setting it up as it is now.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 03/06/2013 :  07:13:51  Show Profile
I keep looking at that project. The thing I keep getting stumped on is the hinge sticking up all the way down the middle of the table. It disrupts my Mexican Train.
Response Posted - 03/06/2013 :  07:46:58  Show Profile  Visit britinusa's Homepage
I don't think the Hinge pin can be above the Table cut!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The player who has the 12-12 begins the first game by placing it in the centre of the table.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Response Posted - 03/06/2013 :  12:19:26  Show Profile
&lt;&lt; I don't think the Hinge pin can be above the Table cut! &gt;&gt;
My piano hinge that runs the top of the table in the middle farward to aft sticks up a little above the table top. I've gotta look at some flush hinges..
Response Posted - 03/06/2013 :  12:21:02  Show Profile
I'm lookin at pine, but it is so hard to stain pine dark without getting an ugly mustard.
Might have to leave it light.
Edited by - redeye on 03/06/2013 12:21:20
glivs
Response Posted - 03/06/2013 :  17:51:43  Show Profile
staining pine - apply a coat of MinWax Sanding Sealer....designed specifically to solve the variable porosity of softwoods
Response Posted - 03/07/2013 :  17:41:40  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by glivs</i>
<br />staining pine - apply a coat of MinWax Sanding Sealer....designed specifically to solve the variable porosity of softwoods
+1 On a previous house I had to stain brand new pine trim to match some birch cabinets. I got the stain from the cabinet maker, but was very concerned about the soft pine ending up with a much darker color. I tried Minwax Pre-Stain Wood Conditioner followed by the stain on a test piece and it was perfect.
As for the table project on the C250, I'll put in a pitch for my table mod that I did last winter. (May not be compatible with some water ballast boats.) It really has been the single biggest improvement I've made, because access to all the storage (forward V-berth and under settees) has been dramatically improved. We can now sleep in the A-berth without hitting our heads or feet.
Two years ago I left the table off the boat all season because it was such a nuisance. Now I wouldn't consider being without it.
I uploaded these before you had your album, and I don't have time to re-upload, so here are some pics using the "old method":
<center>
</center>
Edited by - TakeFive on 03/08/2013 05:57:39
Response Posted - 03/07/2013 :  17:56:05  Show Profile  Visit DaveR's Homepage
Beautiful job Rick!
Response Posted - 03/07/2013 :  20:00:38  Show Profile  Visit britinusa's Homepage
<center>[url="https://www.catalina-capri-25s.net/cgi-local/MBR_gallery.cgi?Album+1000+107"]
<b>Ricks Table</b>[/url]
Really nice table mod</center>
Response Posted - 03/08/2013 :  04:55:35  Show Profile
&lt;&lt; Sanding Sealer....designed specifically to solve the variable porosity of softwoods &gt;&gt;
Interesting.. I've always used a sanding sealer to prevent the poly, or varnish, or whatever else I'm finishing with from being soaked up into the wood and then needing excessive coats. Also to as as a filler, and then you sand the soft sanding sealer rather than the wood. I've never thought os it as a way to alter the stain, as we usually put the stain on first, spraying it on with a gun.
Anyhoo... I've never stained pine much and the few times I have it turned mustard. I normally leave it unstained and the best result was unstained with varnish.. really pretty and did not darken at all. Polyurethane alone even darkened. I did like the results from cetol, stayed pretty light and I was kinda surprised.
I've got a bench and shelves I'm finishing now, pine, and I'll try some stain on it after the sanding sealer.
Still not finding a way to make pine look good when you try to make it look like a dark wood. I guess I'll have to try some more stains on test pieces. So weird how they can change color in the process.. I had a peice of some kind of african tiger wood that went pink when I stained it, but after the coats of poly it looks good, a nice brown color.
Response Posted - 03/08/2013 :  04:57:28  Show Profile
Very nicely done Rick! Esp. with a veneer.
Response Posted - 03/08/2013 :  05:07:01  Show Profile
&lt;&lt; I tried the Minwax Sealer on a test piece and it was perfect. &gt;&gt;
That's a perfect color..
Response Posted - 03/08/2013 :  05:56:41  Show Profile
I need to clarify my prior advice.
The product I used to pre-treat the pine was NOT sanding sealer. It was called Minwax Pre-Stain Wood Conditioner. It does not require any sanding at all. You put it on like a clear oil, let it soak in (and dry, I think), then use your stain.
Sanding sealer has a different purpose, and is not needed if your objective is to get the stain to absorb evenly. Here's a pic of what the can I bought (20 years ago) looked like. If you click on the pic, it will link you to the Home Depot product, which has a redesigned label:
<center>[url="http://www.homedepot.com/p/t/100376201?catalogId=10053&langId=-1&keyword=minwax+wood+conditioner&storeId=10051&N=5yc1v&R=100376201#.UTnfm1eHfTo"][/url]</center>
Response Posted - 03/08/2013 :  07:29:17  Show Profile
Well I gotta admit.. The label pretty much tells it all. No questions there...
I wish some other wood products were better at that!
glivs
Response Posted - 03/08/2013 :  17:00:27  Show Profile
Rick nailed it...my apologies, sanding sealer is for "unstained wood" finishes
