P/S has a two part article on anchor shaft bending that began in the current issue. This month is interesting background info on anchor certification, shank design and strength, and loads. They will start bending anchors in the next issue. A very interesting read, and next month should be very informative.
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
My concern with the article is that they don't really touch on why the anchor shank needs to handle high side loads. If there is a high side load wouldn't you expect the anchor to pivot and reset?
If you are anchoring in rocks (so a pivot isn't possible) that might be important, but most people don't anchor in rocks.
If there is no expectation of side loads then the rectangular aspect ratio of modern anchors makes sense.
I'm curious to read the second one and see how that is addressed.
I think they did offer a scenario with a deeply set anchor that would not turn quickly enough to a rapid change in wind direction, not at all uncommon in thunderstorms. And personally, I have seen a lot of bent anchor shanks over the years. I saw three at Port St. Joe's small marina last month.
