 Round Instruments
juswalk
Initially Posted - 04/24/2013 :  07:00:42  Show Profile
The previous owner of my 1986 Catalina 25 removed the old round instruments and the covered the exterior holes with starboard or something of the like. This still leaves two huge holes above the galley and the exterior patch is not all that attractive.
I can cover the interior holes with something but would like to replace the round instruments. Any ideas where I can find these with the transducers? And, is it worth it?
I currently use my iPad with chartplotting software for navigation and a Hummingbird GPS/fishfinder for speed and depth. Not a huge fan of the latter but it works.
Thanks!
Hull#5484 1986 Catalina 25 TR/FK "Lorelei" NAS Pensacola
dreddick
Response Posted - 04/24/2013 :  07:06:23  Show Profile
Check out Moor Electronics. They may be about the only company still making round instruments.
Response Posted - 04/24/2013 :  08:53:45  Show Profile
Most square instruments made today still fit into round mounting holes.
There are some inexpensive depth finders that fit round holes, like this model:
http://store.humminbird.com/products/410035/HDR_650
I don't like mounting instruments on the cockpit wall for that very reason. On my Catalina 25 I mounted the fish finder and GPS to the teak "eyebrow" since that is easy to replace.
Response Posted - 04/24/2013 :  09:20:03  Show Profile
Signet Marine also makes round ones.
Response Posted - 04/24/2013 :  16:28:56  Show Profile
You could just replace the round holes with this [url="http://www.lewmar.com/product-listing.asp?action=search&type=57"]Portlight[/url]
There used to be a C27 in the slip next to me that had one of these on each side where the instruments used to be.
Edited by - GaryB on 04/24/2013 16:36:09
juswalk
Response Posted - 04/24/2013 :  17:45:10  Show Profile
Thanks for the advice, and interesting idea with the portlight! More ventilation is always great!
Who manufacured the original Catalina instruments (circa 1986)? I ask because I have a line on a set of Moore instruments that should fit perfectly. My only concern is that the thru hulls will be a different size because they are original or replacements but different than original. How common are thru hull sizes?
Thanks again!
Response Posted - 04/24/2013 :  17:51:40  Show Profile  Visit OLarryR's Homepage
I mounted a fishfinder with a Ram Swing mount. Starboard circle covers the outside of the hole but I put the bolt circle within the existing hole held by another piece of Starboard against the bulkhead cabin-side. That Starboard piece serves to bolt up with the bolts holding the outside circle by basically a tight friction mount and the Starboard also serves to mount the Ram Swing Arm from inside the cabin. The Starboard on the inside cannot possibly move since it is also flush with the companionway fiberglas edge and again it's held with the bolts clamped tight from within the existing hole circle, so no addl holes were necessary to be drilled.
More photos are on my website along with details of the install.
Response Posted - 04/24/2013 :  21:56:10  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by juswalk</i>
<br />Who manufacured the original Catalina instruments (circa 1986)?
I think they were all dealer installed or aftermarket. My 1984 Catalina 25 came with almost every feature (I have the original invoice with checkboxes (filled or blank)) and no instrumentation. The only hole in the companionway bulkhead is for the compass.
Response Posted - 04/28/2013 :  07:53:19  Show Profile
I took the guts out of the depthfinder and replaced it with a smaller round depth display that fits behind the glass right inside the old unit. I haven't replaced the speed indicator (looks like crap but it still works). Not sure what I'd replace it with except an extension speaker for the VHF. I'd want a 4.5" round weatherproof unit. Any suggestions?
juswalk
Response Posted - 04/28/2013 :  17:18:47  Show Profile
Good idea on the speaker
Response Posted - 05/01/2013 :  18:37:46  Show Profile
I went to a plastics fabricator and had a plate covering my old round instrument openings then mounted current Raymarine on the plate. It looks fine. The new instruments utilize the old openings for wiring but look custom installed. You don't have to stay with round!
Arlington
Response Posted - 05/02/2013 :  10:00:42  Show Profile
Benjamin my 89 came with Data Marine (DM) Depth and Speed Instruments. I changed a broken DM Depth to a Standard Horizon (SH) model. They are all round, and the SH fit in the same hole. The original DM transducer is compatible with the Standard Horizon. Just check the kHz frequencies and they should be similar, figuring that they operate with a deviation of + or - 5%. My original DM transducer cable simply plugged in the back of the replacement SH. The original instruments are still around, and their are places that repair them. You can also pull up the original manuals online. Just Goggle DM or SH.
All that being said you can get a new Lowrance combo Chartplotter/Depthfinder aka GPS with fishfinder or sonar with the transducer for about $380 now. It is newer technology and provides a lot more information than the original instruments.
http://lr.factoryoutletstore.com/cat/35371/Lowrance-Elite-5-Series-Fishfinders.html?cid=82161&chid=1&gclid=CLO_4abl97YCFYPd4AodLxQAmw
I kept the original instruments, and installed a Lowrance Elite-5 DSI Gold. 'Gold' means it includes Navionics coastal charts on an SD Card. I mounted the included transducer embedded in wax, inside the hull so no holes to drill or fill, I can compare the readings, plus now I have a Chartplotter and GPS and it works just fine.
Doug
Response Posted - 05/02/2013 :  12:18:15  Show Profile
I was able to use a 20+ year old 200khz sonar transducer with my 2013 Raymarine MFD. In general they interoperate just fine if you can figure out the wiring and make an adapter.
Stu Jackson C34
Response Posted - 05/02/2013 :  20:55:09  Show Profile
Datamarine stuff is still supported and they sell new stuff, too. www.dmimarine.com
CarbonSink62
Response Posted - 05/06/2013 :  08:48:12  Show Profile
Does anyone know of a place that sells round disks of teak or starboard to blank off equipment openings? My old compass left a 5 3/8" hole that the new one can pass completely through.
With my punch list getting longer and not shorter, I'm considering just buying a larger compass. The work involved in making a decent looking round plate and then installing & waterproofing that just so I can be at 'ground zero' for making the new hole for the new compass...
My google searches are coming up empty.
Ken
Response Posted - 05/06/2013 :  09:18:14  Show Profile
Seateak sells round pieces of teak, they are sold as winch pads.
I've made my own round pieces of Starboard using a router with a circle cutting jig. It doesn't leave the smoothest cut though, so I cut it slightly oversized and cleaned it up on the lathe.
