 Too much trailer?
TEM58
Initially Posted - 05/01/2013 :  13:47:52  Show Profile
Considering purchasing this trailer. The owner says it's 30' long, rated for 8500lbs capacity, torsion axles, surge brakes, and in very good working order. It's a 2007 EZ loader galvanized, and the price is extremely reasonable. I know some mods are necessary to carry a 25' SK (keel rest, possibly different bunks, etc), and fortunately everything is adjustable on this trailer. My question is: should I be concerned that it's a lot longer than needed? I'm thinking the extra length may negate me needing to get an extension for use on the ramp. Any thing else I should consider?
Tim M
“Perfect Match II”
2003 C350 #35
Cruising FL
PO "Wine Down"
2000 C250 WK #453
PO "Perfect Match"
1983 C25 SR/SK #3932
Lake Belton
Belton, TX
Response Posted - 05/01/2013 :  15:36:32  Show Profile
I thought the next jump on axles from 3500 was to 5000 pounds, where does he get the 8500? Is it 5k axles with smaller/lighter channel steel?
TEM58
Response Posted - 05/01/2013 :  16:35:34  Show Profile
<br />I thought the next jump on axles from 3500 was to 5000 pounds, where does he get the 8500? Is it 5k axles with smaller/lighter channel steel?
You are correct, but assuming they are 5k axles then the capacity would seem right given the weight of the trailer. My only real concern is that the trailer is designed for a somewhat longer hull than the C25.
This is from the manufacturer's web site:
Model/Hull length/ TEZB 28-30' 8500
# Bunks 4
Type Axle TORSION
Tire size ST23580R 16E
Width btw fenders 76"
Overall width96"
Overall length 30'3"
Shipping Wgt 2015
Response Posted - 05/01/2013 :  16:50:48  Show Profile
I never measured my trailer but i'd bet it's close to 30' although it has lighter weight axles. It has a short extension also. I like the longer length. Just have to be careful when turning the corner.
The longer length just means the boat will ride farther back from the tow vehicle which should make it easier to tow.
WesAllen
Response Posted - 05/01/2013 :  17:24:46  Show Profile
I checked my trailer that was built to haul my C25 by 'Loadmaster'. The Axle capacity is 10,600# but load capacity is 8,500#. It is just under 30 feet long total and works real well. The portion of the trailer behind the axles goes almost to the transom. That makes it real easy to tie down which also helps to stiffen the trailer.
TEM58
Response Posted - 05/01/2013 :  17:47:14  Show Profile
Thanks folks. I also found a guy very near me that has a factory trailer for a C25 SK. Unfortunately he didn't want to sell it, but I'll be able to get exact measurements for all the critical parts and spacing.
Response Posted - 05/01/2013 :  20:51:15  Show Profile
Could you pass those measurements along? I need top make sure my bunks properly support my boat when I pull it out later this month or in June.
TEM58
Response Posted - 05/02/2013 :  04:50:03  Show Profile
<br />Could you pass those measurements along? I need top make sure my bunks properly support my boat when I pull it out later this month or in June.
Can do
AtEase
Response Posted - 05/06/2013 :  19:58:34  Show Profile
Better too much trailer than not enough.
ftworthsailor
Response Posted - 05/07/2013 :  19:50:39  Show Profile  Visit ftworthsailor's Homepage
I just acquired a c-25 SK on a nice trailer. Let me know if you want me to post pictures and measurements of this trailer. It is a tandem axle trailer with a nicely done tongue extension.
TEM58
Response Posted - 05/07/2013 :  20:01:07  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ftworthsailor</i>
<br />I just acquired a c-25 SK on a nice trailer. Let me know if you want me to post pictures and measurements of this trailer. It is a tandem axle trailer with a nicely done tongue extension.
Thanks. I made arrangements today to go measure the factory trailer I found near my house. I had actually spoken with Bill, and had planned to drive up and look at the SK C25 you ended up buying! I was debating buying it just to get the trailer but was really hesitant to take on a second boat. Then I ended up with an emergency that kept me from making the trip anyway. Good luck with it, you got a heck of a deal!
