 Patching an Inflatable
hinmo
Initially Posted - 05/12/2013 :  18:36:19  Show Profile
My 1 year old West Marine hard-bottom has a couple leaks not covered by warranty. I bought the $40 kit patch kit from WM. 1 small tube of glue and 6 4inch patches. The first took, the second didn't.
The second hole required me to cover partially over a seam. I probably did not cover enough of the seam on the first try.
Any tips? Now I am out of glue and am looking at Stabond, two part pvc adhesive....anybody have experience? Its $23 at WM.
"Kukla" '83 FK,SR
hinmo
Response Posted - 05/17/2013 :  19:04:01  Show Profile
Whaa! - nobody?
Response Posted - 05/18/2013 :  05:45:35  Show Profile
Not a lot of experience here but I did a patch on my inflatable air floor but not at a seam. I used a roller to get any air bubbles out then put a piece of I-Beam on top until it was dry. It held.
KenDavis
Response Posted - 05/18/2013 :  21:17:50  Show Profile
There is a difference between PVC and hypalon inflatable patch kits.did you get the right one? seams are harder to seal use extra glue and patch while it is inflated tight.
SEAN
Response Posted - 05/19/2013 :  04:59:11  Show Profile
the 2 part is a stronger glue then single , i think its supposed to be scuffed and a little heat helps , pressure over the repair to
Response Posted - 05/19/2013 :  09:10:33  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by KenDavis</i>
<br />...patch while it is inflated tight.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
