 Loos Tension Numbers
Steve Raffel
Initially Posted - 05/17/2013 :  10:42:26  Show Profile
I use 31 for my uppers and 29 for my lowers. That works fairly well. What would be a good range of numbers for the backstay. I have been using 32 which seems OK but I have no way of knowing.
Thanks.
Steve Raffel
C 250 WK #408
Response Posted - 05/17/2013 :  15:15:35  Show Profile
Do you have a split backstay or single? It sounds like single you have single, but that concerns me because if it's a single offset backstay, then your tensions on port and starboard should not be equal.
I have split backstays, but the connection point is not perfectly centered, and even with that slight offset, it makes a measurable difference in the tension of the port vs. starboard uppers and lowers.
FWIW, your lower tension sounds a bit high. You are probably losing any pre-bend that your uppers have created.
FYI, I record tensions, but I do it by eye and feel. Tension the uppers enough to create 1" prebend and equalize them with a halyard to make sure the mast is vertical, tension the lowers so that they are ever so slightly loose on the leeward side when close-hauled (takes a few sails to get them right), set the forestay for 4" mast rake, tension the backstay enough to make sure I don't have any pumping of the forestay. Then I go back and re-adjust the uppers and lowers, since they're affected by the other adjustments.
When it's all done I check tension to make sure I'm never more than ~15% of maximum working load while at rest. What really counts is that you never exceed 100% when the boat is sailing in a heavy blow.
Steve Raffel
Response Posted - 05/20/2013 :  13:20:30  Show Profile
Rick,
Thanks for your helpful reply. My boat has a split backstay.
