 110v Outlet Failure
Initially Posted - 06/10/2013 :  17:57:19  Show Profile  Visit britinusa's Homepage
The rest of my shore power system was built using Blue Sea components.
Looking for a 'Marine' GFCI dual 110v outlet.
Only one I can find is 'Marinco', is that it?
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 06/11/2013 :  19:39:04  Show Profile
Ummm... Why not a Hubbell or Leviton? Sure it's not authentic "marine" gear but it will work.
Response Posted - 06/11/2013 :  20:02:58  Show Profile  Visit britinusa's Homepage
The failed item was a Leviton!
The ground screw was totally corroded and the Test/Reset non functional.
frog0911
Response Posted - 06/12/2013 :  14:28:42  Show Profile
I have had mine in the boat since '04 and have not had any problems. The one thing I did was to spray all the connections with WD-40 and then whipe them down with a paper towel. Knock on wood, to this day I have not had any problems. Forgot to mention I picked up all the parts at Home Depot.
Edited by - frog0911 on 06/12/2013 14:30:34
Response Posted - 06/12/2013 :  17:35:55  Show Profile  Visit britinusa's Homepage
20 minutes and the receptacle was replaced tested and in service!
Battery charger is now running sweetly
Also called BlueSea about the lamp failures in the Blue Sea switches... they are sending replacement LED's gratis. now that is customer service! I told them that the switches were 7 years old and probably past warranty! Not a problem. Can you spell SWEET!
