 Are speed logs just inductively coupled?
Initially Posted - 07/12/2013 :  19:38:32  Show Profile  Visit delliottg's Homepage
I installed an older Humminbird fishfinder on SL the other day, using the toilet wax method. It also came with a thermometer / speed wheel designed to be mounted on the transom. I unscewed the speed wheel portion to see if the temperature part would read if I stuck it in the wax as well, which it did. There were no electrical connections between the two, so they must be inductively coupled, right? Now I'm wondering if i could have set it next to the old speed log (which still works just fine), and whether it could sense the magnetic pulses from it? If so, I could remove the Bidata display entirely, and replace it with the fishfinder.
David
C-250 Mainsheet Editor
Sirius Lepak
Response Posted - 07/13/2013 :  06:54:47  Show Profile
Some are, some aren't. Many RPM sensors use a small permanent magnet in the rotor or spindle and a magnetic reed switch or "Hall Effect" semiconductor in the pickup. When the magnet passes the sensor it creates a series of pulses and the circuit counts the pulses. Thru the magic of TTL circuitry and math it displays a speed on a display.
The rotor passes within a few mm of the sensor.
Not sure but I don't think 2 speed sensors nearby one another would interact - they might - might be worth a try.
Edited by - Voyager on 07/13/2013 07:14:27
