 Simplle solution to avoid scratching port lights
zeil
Initially Posted - 07/28/2013 :  09:13:57  Show Profile
Simple solution to avoid scratching port lights during transportation (thank you Peter)
Henk & Johanna
Edited by - zeil on 07/28/2013 09:16:02
Response Posted - 07/28/2013 :  09:36:43  Show Profile
But has it already bent that forward toggle?
Response Posted - 07/28/2013 :  09:45:14  Show Profile  Visit delliottg's Homepage
What is the white cylinder made from? Kinda looks like the pencil eraser refills I used to use when I did hand drafting and had an electric eraser. I think they'd be too small though.
zeil
Response Posted - 07/28/2013 :  15:13:20  Show Profile
It did bend years ago... straighten it may weaken it.
With this square "cutting board", type material insert it should be no longer or at least less of a problem during mast raising... It is a detail to carefully watch.
(Catalina uses the exact same material for the hatch lid and sides of the hatch slider on the C250) Perhaps someone of the forum knows the name of the material)
Edited by - zeil on 07/28/2013 15:13:52
Response Posted - 07/28/2013 :  15:24:30  Show Profile  Visit britinusa's Homepage
Starboard!
Response Posted - 07/28/2013 :  16:03:17  Show Profile
High-density polyethylene (HDPE). Starboard is a brand name for HDPE formed into lumber.
Response Posted - 07/28/2013 :  16:39:41  Show Profile
FWIW, prior to raising my mast I just tie my shrouds to the lifelines with a 12" line and a loose half hitch. It keeps the T-bolts aligned, and the lines just fall off when the shrouds are tensioned away from the lifeline. Should work with outboard (WB) chainplates just like it does on my inboard (WK) ones.
