 Connector type for side mount battery terminals
Initially Posted - 02/03/2014 :  18:03:35  Show Profile
Haven't started the tow vehicle since November so I want to purchase an automatic battery charger similar to what I have for the boat battery. Except, the truck battery has the side terminals and I am not sure what kind of connector would be compatible. I hope alligator clips are not my only option!
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 02/04/2014 :  06:05:33  Show Profile
Cut the alligator clips off and attach ring terminals that fit the bolt in the side terminal? You can add quick connects in the line too if you want to be able to quickly remove the charger from the battery.
Response Posted - 02/04/2014 :  18:19:22  Show Profile
Whatever kind of mating plug you use, it's always a good idea to make sure an accidental contact with metal (a wrench, screwdriver) cannot short out the terminals. Further you should install a 20A fuse in line with the connector and the plug/receptacle to prevent a fire.
Response Posted - 02/06/2014 :  17:50:13  Show Profile
The two wire, single connector quick disconnect with male negative/female positive side attached to the battery is the safest approach.
