 Catalina Direct spinnaker crane
Initially Posted - 07/07/2014 :  18:56:42  Show Profile
Anyone here using the above referenced and running the spinnaker halyard inside the mast?
Any issues, additional sheaves required to achieve this?
Response Posted - 07/07/2014 :  19:00:13  Show Profile  Visit britinusa's Homepage
Pretty sure the C250 and C25 spinnaker crane are the same thing.
Our only issue with it has been the need to flip the block at the top of the halyard aft away from the furler to prevent the furler snagging the spin halyard line. I've taken to flipping the spinny block aft to port and securing the spinny halyard aft so that it crosses over the upper shroud and then down to the port side lifeline.
Response Posted - 07/07/2014 :  20:11:08  Show Profile
Thanks Paul,
Would a smaller block (off the crane) alleviate it interfering with the furler?
TCurran
Response Posted - 07/08/2014 :  05:14:08  Show Profile
Used one on Island Time without an issue. What I remember it was pretty much mount as shipped and use. I believe it comes with the longer clevis pins to mount on the masthead, so nothing additional or any alteration was needed. There is a difference between a SR and TR masthead, I believe the TR is narrower but the CD kit for TR comes with shims to make it fit.
Lee Panza
Response Posted - 07/08/2014 :  07:12:27  Show Profile  Visit Lee Panza's Homepage
Our only issue with it has been the need to flip the block at the top of the halyard aft away from the furler to prevent the furler snagging the spin halyard line...
This is what I was concerned about when I was modifying my own rig for a spinnaker, and why I went to the trouble of fabricating a spinnaker crane myself to carry the block farther forward. We discussed this issue in a thread last year:
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=27742
I wish Catalina Direct would redesign their crane to move the block farther forward and to keep it there.
(edit)...
In retrospect, I think a single piece of stainless steel angle would have been sufficient; the block would have been a little off-center, but probably not enough to be an issue.
Edited by - Lee Panza on 07/08/2014 07:16:15
Response Posted - 07/08/2014 :  07:41:13  Show Profile
Spoke with my goto guy at Harken this morning. He actually recommended a 57mm swivel block. As he is unaware of the shortcomings of the CD crane, I'm going with the 40mm. If the 40mm interferes with the furler I may go to a 29mm.
sweetcraft
Response Posted - 07/16/2014 :  22:07:38  Show Profile
My spinnaker halyard is outside the mast and clear of the forestay. The spinnaker is a reaching 3/4 oz and needs clearance to either side. The block of the crane has to clear everything. Seems with the furler there could be wear right at the swivel block on one side or the other.
Response Posted - 07/17/2014 :  06:49:55  Show Profile
Good points Jim. I was so focused on he spinnaker halyard going inside the mast that I haven't thought about any new issues this change might present. Yeah, even though the crane places the spinnaker halyard block forward, the external line is bound to chafe against the furler. My instincts tell me that by this time next year, I will have modified the crane and the halyard will be internal.
Heartbeat
Response Posted - 07/17/2014 :  20:17:45  Show Profile
What is a spinnaker crane? I just run the kite block off the front of the chickenhead. It cleared the rollerfurling when I had one. Standard 2" Harken block. (Yeah, all internal halyards.)
Matt
Response Posted - 07/18/2014 :  07:17:03  Show Profile
Matt
What is a chickenhead?
The definition of "creation of demand" = creating demand for a product or service that didn't exist before. Sometimes that's what I think of the spinnaker crane. Is it truly necessary?
Matt, you have my attention. I see you have a tall rig which has the narrower masthead. You were able to run your spinnaker halyard internally without chafing against the inside if the masthead?
Edited by - OJ on 07/18/2014 07:20:06
Heartbeat
Response Posted - 07/18/2014 :  09:51:31  Show Profile
Not sure why it is called a chickenhead, but the prior/first owner called it that. It's the casting that goes on the top of the mast and holds all the sheaves. (I think you knew that, but I thought I would clarify.)
So only the main and jib halyards exit through the chickenhead. The kite halyard exits the mast about 8" below the chickenhead through a double roller offset from the centerline of the mast. (Harken's "in-line exit" 308. I think mine is on the port side.) Hang a swivel block off the front of the chickenhead and bob's yer uncle.
It's a bit busy up there, but works fine. I even use the gin pole to the kite halyard to raise and lower the mast.
Matt
Heartbeat
Response Posted - 07/18/2014 :  09:55:28  Show Profile
I'll try and take a picture for you if you like.
Oh, back to this spinnaker crane thingey. Why was that again? I work REALLY HARD to lower weight aloft. Why add? Why not just buy a tall rig chickenhead? At least it's aluminum and not stainless.
Matt
Edited by - Heartbeat on 07/18/2014 09:59:30
