After a great weekend on the water over Independence day weekend, I was snugging JD up to the Bow Rollers when a loud bang stopped everything.
<center> <b>Broken Trailer Winch Drum Bolt</b> While snugging JD up to the bow rollers this past weekend the Trailer Winch Drum Bolt Sheered. Bang!</center>
I'll be changing out all of the bolts on the Trailer Winch system this weekend! Stitch in time!
I was able to replace one of the two bolts in the winch mechanism but the other, the one that failed, is badly corroded within it's bearing and requires drum replacement.
I could not find a replacement drum, but a completely new winch, original replacement, found on the web for less than $100 including shipping. So it's on it's way.
I intend to lube the drum bolt of the new one at least annually. The specs state that the winch has lifetime lubricated seals, but as the warranty is only 3 years, I guess that means they are lubed for 3 years.
Anyone with a winch on their trailer might want to take a looksee and decide if it needs a stitch in time (lube) to prevent future failure.
-------------------------------- Total : $97.43 --------------------------------
The two brands that I found all over the web were DL (Dutton-Lainson) and Fulton. The OEM was Dutton Lainson. Figured stick to the OEM, at least the holes in the trailer to mount the winch 'should' match.
Prices varied from $77 to $150, Ordered from diytrailerparts.com as they were $20 less than even Amazon.
