 Length of jib sheets
kiko
Initially Posted - 09/11/2014 :  10:26:46  Show Profile  Visit kiko's Homepage
Anyone offhand know the length that I'll need for jib sheets for a std rig cat 25? Would be for genoa. Only want to use one line and not two.
thanks!
Response Posted - 09/11/2014 :  11:07:52  Show Profile
See page 20 of the C25 parts catalog
Response Posted - 09/11/2014 :  11:15:08  Show Profile
The general rule is 1.5 X boat length. I did that, but an additional couple of feet per side would be nicer. I would say 40' - 42'.
Heartbeat
Response Posted - 09/11/2014 :  13:42:20  Show Profile
I think we are using ~45' but when we have the pole up, one of the sheets goes over it. Easier to cut off the extra than to buy a new one...
Response Posted - 09/12/2014 :  18:47:00  Show Profile
Using the boat length x 2 x 1.5 gives you 75 ft. However, 72 ft. will work. Use 5/16" line unless you frequently sail in strong winds and need/prefer 3/8' line. My preference is 8mm BZZZ line from New England Ropes, a very good single braid that flies through the blocks. Available on Ebay.
http://www.ebay.com/itm/like/351008841413?lpid=82
Edited by - dmpilc on 09/13/2014 07:39:31
Response Posted - 09/12/2014 :  20:37:34  Show Profile
Also, keep in mind that a low clew, hank on 110 won't need as much as a my high clew, roller 150
hewebb
Response Posted - 09/13/2014 :  03:34:10  Show Profile
I bought 60' of 1/2 inch and it was barely enough, used it twice. It did work but decided to go smaller and longer. Went back and bought 70' of 3/8 inch and it works better. There is quite a bit more length with the 70' than you really need and I may trim it. I fly a 150 on a furler.
I still have the 60' of 1/2 inch Solid blue sta-set if you are interested. It sells for $2.40 a foot new.
