 wall thickness - pulpit tubing
Initially Posted - 09/18/2014 :  09:08:56  Show Profile
I need to fill in a couple-three holes in my stern pulpit - using pop rivets. So I can order the correct (grip) rivet, does anyone know the wall thickness of the tubing?
The grips on 3/16" stainless steel, closed end (sealed), dome head rivets range from 0" to 1/8" and then 3/16" to 1/4" and up.
Edited by - OJ on 09/18/2014 09:16:18
Response Posted - 09/18/2014 :  09:30:31  Show Profile
If your just filling the hole and not attaching anything use the 0-1/8. Catalina used a good quality tubing but even a heavy duty tubing isn't thicker than 1/8"
Heavy duty tubing is @1/16"
Standard tubing is @3/64"
Edited by - islander on 09/18/2014 09:53:19
Response Posted - 09/18/2014 :  11:05:44  Show Profile
Having cut through my stern rail, I was gonna say probably around 1/16"--certainly not as much as 1/8".
Response Posted - 09/18/2014 :  11:55:24  Show Profile
0" to 1/8" it is then.
If it weren't for the price of stainless steel rivets I wouldn't even be asking.
I love The Bolt Depot!
Response Posted - 09/18/2014 :  11:56:31  Show Profile
Dave, what's up with your signature pix?
Response Posted - 09/18/2014 :  14:08:31  Show Profile
Shutterfly has made it so I can no longer access the thumbnails I used in the signature. But if you click the empty boxes, you'll see the full-sized versions, as before. I haven't worked up the energy to do something about it...
Response Posted - 09/18/2014 :  14:48:39  Show Profile
Hmm, I use Shutterfly . . . am I next?
