 Polishing aluminum window frames
sailboat
Initially Posted - 11/19/2014 :  22:27:22  Show Profile
On our 1981 Cat 25 the original aluminum window frames look tired to say the least. I have read that a product called Marine 31 works great on aluminum but that it should not be used on clear coated or anodized surfaces. Were those window frames ever clear coated or anodized? Or what recommendations are there to brighten them some?
Mike
DavidBuoy
Response Posted - 11/20/2014 :  06:14:06  Show Profile
Mike,
I believe that they are anodized and to get the coating off they would need to be chemically striped. I remember reading this from somebody else that did this. Next time i redo my windows, i would love to powdercoat them white.
-Rob
Response Posted - 11/20/2014 :  07:13:53  Show Profile
Yep, they are anodized. Short of disassembling the frames, having them stripped and re-anodized . . . Nevr Dull may be the next best thing. You will, however, probably only see minimal improvement.
http://www.nevrdull.com/
kiko
Response Posted - 11/20/2014 :  10:51:08  Show Profile  Visit kiko's Homepage
used MEK and a scotch brite pad and my frames turned out really nice.
sailboat
Response Posted - 11/20/2014 :  14:53:15  Show Profile
Thanks, I will give that a try. Where did you purchase the MEK?
Response Posted - 11/20/2014 :  18:05:07  Show Profile  Visit britinusa's Homepage
Be super careful with MEK - nasty stuff especially near your eyes.
sailboat
Response Posted - 11/20/2014 :  22:50:36  Show Profile
Thanks. That's another reason it is banned from navy warships, volatility being the main culprit.
Akenumber
Response Posted - 11/22/2014 :  19:03:27  Show Profile
It's just epoxy thinner. Does work well though. Be carefull. I don't think you can get it in all states, but home depot should have it.
Response Posted - 11/23/2014 :  03:37:35  Show Profile
That may explain why my local HD (here in PA) sells "MEK Substitute"
Response Posted - 11/23/2014 :  03:38:05  Show Profile
glen
Response Posted - 11/24/2014 :  08:34:21  Show Profile
A number of years ago, we repainted Adventure, and during that project since the windows had been removed, I decided to polish the trim pieces. I used a buffing wheel and polishing compond on a bench grinder. I should say I used a number of sticks of compound and wheels. The outcome was wonderful, and now they look like polished stainless. But it was a lot of work. Perhaps stripping them first would have made the job easier, but!!!
Jan Briede
Response Posted - 11/24/2014 :  10:47:48  Show Profile
When I had mine out (and I still need to do two ports) I just gave a very good scrubbing with comet and they look pretty darn decent (see also my blog post of 10/5/2014: http://vanomad.blogspot.com/2014/10/seaford-1052014.html)
Jan
JB
Response Posted - 11/24/2014 :  14:17:33  Show Profile
Won't these abrasive cleaners remove the anodization, if so would you seal it with varnish or some other clear coat?
Jan Briede
Response Posted - 11/25/2014 :  06:49:10  Show Profile
JB, truthfully I am not sure; and I am not sure if it matters. My aluminium does not need to be shiny, and a good friend of mine who works in boat restoration at a marina basically recommends comet and/or soft scrub for almost any job on a boat (except wood and canvas/sails ... I did not talk stainless with him).
